#988
I resizied my ssd from 120gb to 70 gb with mini partition tool. Windows 10 side of ssd is 70 gb. I formatted other side(50gb) as hfs plus with paragon partition manager. Then i installed mavericks os x on hfs plus side perfectly. But i tried to install el capitan but i couldnt. it says "a gpt partitioning scheme is required" during the installation phase. Any opinion about it?
#991
I'm assuming the Mavericks was a Distro or pre patched image as OS X will only install to a GPT partition.
You can install onto MBR for El Capitan with these modifications,
http://www.insanelymac.com/forum/files/file/426-el-capitan-mbr-patch/
