by: rEApEr_TGB
#12117
Yes it is.
#12119
Well that's strange. Does the BIOS detect the drive?
#12121
That's strange. Must be a bad install I'm afraid. You'll need to install again.
by: rEApEr_TGB
#12124
Okay but I'll do that tomorrow
#12128
Let me know how it works out. If you need more help open your own support topic so you have it for future reference if needed.
by: hashimoto16
#15168
Ok... let me continue from the right topic ^^ sorry for many troubles Shane...
So, if I write the flag nv_disable=1 my screen will stay black forever ^^
If I don't write that flag, my screen will be like a code bar...
by: Floris-Jan
#22129
I installed using your el capitan image V2, after the install (didnt need any bootflags to get into the installer) i did all the command line stuff in the terminal wich al went fine (got my pc working with yosemite the same way) now after the install and the post install terminal stuff i cant get into my installed os X, enoch can detect the installed drive but every time kernel optime errors (even with UseKernelCache=no and npci 0x2000) got some insight for me?
Sry for my bad english im dutch haha
If its too much i can alway go back to yosemite^^
Thanks shanee for all your amazing work!!!
#22170
@Floris-Jan, Remove the prelinkedkernel and run the kextcache command again in post install.
by: Floris-Jan
#22189
@Shaneee, Thanks will try that tonight and inform you with the results
@Shaneee again kernel opcode errors. Did find that the kextcache command gave alot of can't find symbol in __kernel__ (see picture)
Any ideas?
( tried several times)
Im installing from another internal hdd (wich i restored using transmac) but that can't be it right? Install goes perfectly and all the commands work too, i checked every step to see if everything showed like its supposed to
  • 1
  • 8
  • 9
  • 10
  • 11
  • 12
  • 13
