#12093
Boot with UseKernelCache=No
#12101
Again what? Just continue with the setup.
by: rEApEr_TGB
#12103
So I have to do the Installer again?
#12104
No if it's installed you need to use the USB bootloader to select the installed HDD.
by: rEApEr_TGB
#12105
So I have to use a specific boot flag?
#12107
Boot the USB. When you see the Enoch menu hightlight the installed HDD and type -v UseKernelCache=No then press enter and it will start to boot the installed system.
by: rEApEr_TGB
#12112
Image There is only the USB selectable
by: rEApEr_TGB
#12113
Image Could it have something to do with this?
#12116
The HDD is connected yes? Check the BIOS for the SATA setting and make sure it's on AHCI.
  • 1
  • 7
  • 8
  • 9
  • 10
  • 11
  • 13
