#15841
No with Clover press the space bar on the HDD/USB and choose boot without caches.
by: Blaggah
#15849
That feature seemed to be long gone in the new version on clover bootloader. I'm using the latest version which is 4012 I believe. I've yet to figure out which version it was last available in.
#15851
Add the bootflag UseCaches=No then.
by: Blaggah
#15875
Ok, will do.
by: liosliante
#15928
I am having problems. First I was having the AppleUSBEHCI looping issue, and now, if I use these files for installing Sierra, it gives me a kernel panic error. I can not enter into the installer.
Please help me!!!
#15950
liosliante wrote:I am having problems. First I was having the AppleUSBEHCI looping issue, and now, if I use these files for installing Sierra, it gives me a kernel panic error. I can not enter into the installer.
Please help me!!!
That's because this fix is for El Capitan. You need the Sierra fix. How did you make the Sierra Installer?
by: Nurrl
#16916
Hi Chad, I finally managed to install OS X without bugs on my HomeMade PC with AMD FX-8350 Black Edition 8-).
But I was experiencing some weird
busy timeout[0], (60s) kextd wait(0): 'pci****,***'
, and I found that the problem was that the Shaneee's USB Fix has a duplicate .kext in PlugIns dir from IOUSBHostFamily.kext and IOUSBFamily.kext called AppleUSBXHCI.kext.
So I just fixed it by doing(Assuming you used the USB Fix in S/L/E) :
sudo mv /System/Library/Extensions/IOUSBFamily.kext/Content/PlugIns/AppleUSBXHCI.kext ~/Desktop && sudo reboot
Now my Hackintosh Sierra 10.12.3 with AMD FX-8350 and GTX 970 works really great, thanks for all ;D
#16931
Glad you worked that out and thanks for mentioning it.
by: Nurrl
#16958
No problem, the goal is to help other peoples to achieve their Hackintosh ;D
#24067
This method is now outdated. See the new fix here, viewtopic.php?f=23&t=2073
