by: riteshdahiya9910
#13265
Tried every possible fix , my usb mouse doesnt work .. keyboard works in sierra downloaded from shaneee amd for windows ... Can someone please help?
#13269
riteshdahiya9910 wrote:Tried every possible fix , my usb mouse doesnt work .. keyboard works in sierra downloaded from shaneee amd for windows ... Can someone please help?
For Sierra try this,
https://www.dropbox.com/s/vf6483vvt3vml86/USB%20Sierra_Test_V2.3.zip?dl=0
#13279
Use the extensions provided ... Now it goes in an infinite loop with appleusbehci stop and restart :(
#13280
Did you boot with UseKernelCache=No ?
#13285
Let it sit. Sometimes this message appears but the system still works.
by: TomB42
#14625
How to I apply this USB fix to my HDD? (Totally new to Hackintosh, besides reading loads on this forum)
Using Transmac (and thanks to Shaneee) I've managed to install and boot El Capitan from my HDD after following the Post Installation guide but have no working USB ports. (Have to boot using UseKernelCache=No as the last line of code in Post Inst. results in "Resource Busy" and requires reinstall)
After using Transmac again I applied the fix from here to my USB Installer in VMWare using this guide, (after removing the kext files stated on the insanelymac download page) and re installed, followed post installation again.. but I have the exact same result. Boots from HDD but no USB. Any help is much appreciated.
#14632
So you got the files copied to the HDD with VMWare? Boot with -v UseKernelCache=No
by: TomB42
#14637
No I tried putting the USB fix on to the USB installer using kext wizard in VMWare, I don't have a Mac. I just don't know how to install the USB fix to the HDD.
Booting HDD with -v UseKernelCache=No results in the same, no USBs are working.
Would plugging this HDD into the PC running OS X in VMWare and using this guide & kext wizard work?
