by: bernek
#43118
Shutdown is working now ! and AMD RX580 is shown correctly :D what a great update. I also hope for improved Metal performance on applications that support it.
Mojave would be nice yes but I don't know how long it takes to modify the kexts and everything that is needed.
Shaneee liked this
by: mido_fedo
#43119
sorry but i have a few questions and excuse me i'm still new in hackintosh
1: from where can download macOSUpdCombo10.13.6.pkg
2: how i will boot from clone? and can i do this update without clone step?
3: 10.13.6 Kernel can work with macOS 10.13.2?
#43120
mido_fedo wrote:sorry but i have a few questions and excuse me i'm still new in hackintosh
  1. Here, https://support.apple.com/kb/DL1970?locale=en_US
  2. Same way you boot the current disk with Clover. Your current boot drive will still boot Clover and to the clone without issue.
  3. Not sure but there's no need for that.
mido_fedo liked this
by: mido_fedo
#43124
thanks but last one when i start download the file is .dmg not .pkg like the one in the video is that ok?
#43125
Yeah it's inside the DMG :thumbup:
by: mido_fedo
#43126
by: sneake9
#43129
Обновляюсь с 10.13.3 до 10.13.6 . при попытке запустить в терминале rp получаю . sudo: rp: command not found что не так?
by: mrringht
#43131
@Shaneee, I got below error when trying to update my Hackintosh @ Ryzen 10.13.3 to 10.13.6. Any advise?
Oct  4 23:12:04 Weis-Mac-Pro Installer[485]: @(#)PROGRAM:Install  PROJECT:Install-1000
Oct  4 23:12:04 Weis-Mac-Pro Installer[485]: @(#)PROGRAM:Installer  PROJECT:Installer-920
Oct  4 23:12:04 Weis-Mac-Pro Installer[485]: Hardware: iMac14,2 @ 3.00 GHz (x 16), 16384 MB RAM
Oct  4 23:12:04 Weis-Mac-Pro Installer[485]: Running OS Build: Mac OS X 10.13.3 (17D102)
Oct  4 23:12:05 Weis-Mac-Pro softwareupdate_notify_agent[487]: Handling notification event: LoginDone
Oct  4 23:12:05 Weis-Mac-Pro softwareupdate_notify_agent[487]: AssertionMgr: Take com.apple.softwareupdate.NotifyAgentAssertion-LoginDone assertion with type BackgroundTask for pid 487, id 0x818F
Oct  4 23:12:05 Weis-Mac-Pro softwareupdated[488]: softwareupdated: Starting with build 10.13.3 (17D102)
Oct  4 23:12:06 Weis-Mac-Pro softwareupdated[488]: Initiating startup cleanup
Oct  4 23:12:06 Weis-Mac-Pro softwareupdated[488]: This could possibly be a restart after a crash.
Oct  4 23:12:06 Weis-Mac-Pro softwareupdated[488]: authorizeWithEmptyAuthorizationForRights: Requesting provided rights: 8
Oct  4 23:12:06 Weis-Mac-Pro suhelperd[490]: SUCleanup: /Library/Updates/AtomicUpdates - 0, /private/var/db/.AtomicSUStatus - 0.
Oct  4 23:12:06 Weis-Mac-Pro Installer[485]: macOS High Sierra 10.13.6 Update  Installation Log
Oct  4 23:12:06 Weis-Mac-Pro Installer[485]: Opened from: /Volumes/Hackintosh/Users/man/Desktop/Video_Update_Files/macOSUpdCombo10.13.6.pkg
Oct  4 23:12:08 Weis-Mac-Pro softwareupdated[488]: authorizeWithEmptyAuthorizationForRights: Requesting provided rights: 1
Oct  4 23:12:08 Weis-Mac-Pro softwareupdated[488]: /Library/Bundles does not exist - watching for directory creation
Oct  4 23:12:08 Weis-Mac-Pro softwareupdated[488]: Previous System Version : 10.13.3 (17D102), Current System Version : 10.13.3 (17D102)
Oct  4 23:12:08 Weis-Mac-Pro softwareupdated[488]: BackgroundActivity: Activity check-in with Interval 21600
Oct  4 23:12:08 Weis-Mac-Pro softwareupdated[488]: Adding client SUUpdateServiceClient pid=487, uid=503, installAuth=NO rights=(), transactions=0 (/System/Library/CoreServices/Software Update.app/Contents/Resources/softwareupdate_notify_agent)
Oct  4 23:12:08 Weis-Mac-Pro softwareupdated[488]: xpc_add_bundle /System/Library/PrivateFrameworks/SoftwareUpdate.framework/XPCServices/ManualProductStasherService.xpc
Oct  4 23:12:08 Weis-Mac-Pro softwareupdate_notify_agent[487]: Notifying with params: {
	    AutomaticCheckDisabled = 1;
	    UpdateNotificationsOnly = 1;
Oct  4 23:12:08 Weis-Mac-Pro softwareupdate_notify_agent[487]: appstoreupdateagent notified
Oct  4 23:12:08 Weis-Mac-Pro softwareupdate_notify_agent[487]: AssertionMgr: Cancel com.apple.softwareupdate.NotifyAgentAssertion-LoginDone assertion for pid 487, id 0x818F
Oct  4 23:12:17 Weis-Mac-Pro Installer[485]: recoveryPartitionVersionForVolume: could not get recovery version information for mount point /Volumes/Hackintosh: Unable to find boot helper partition. (-69737)
Oct  4 23:12:31 Weis-Mac-Pro deleted[388]: diskmanagement: [DMManager(PrivateMethods) clientConforms:error:]: currentThread=13831=0x3607 expectedThread=21003=0x520b
Oct  4 23:12:31 Weis-Mac-Pro deleted[388]: diskmanagement: [DMManager(PrivateMethods) clientConforms:error:]: currentThread=14851=0x3a03 expectedThread=21003=0x520b
Oct  4 23:12:33 Weis-Mac-Pro Installer[485]: recoveryPartitionVersionForVolume: could not get recovery version information for mount point /: Unable to find boot helper partition. (-69737)
Oct  4 23:12:35 Weis-Mac-Pro deleted[388]: diskmanagement: [DMManager(PrivateMethods) clientConforms:error:]: currentThread=16387=0x4003 expectedThread=21003=0x520b
Oct  4 23:12:35 Weis-Mac-Pro Installer[485]: recoveryPartitionVersionForVolume: could not get recovery version information for mount point /: Unable to find boot helper partition. (-69737)
Oct  4 23:12:35 Weis-Mac-Pro Installer[485]: InstallerStatusNotifications plugin loaded
Oct  4 23:12:36 Weis-Mac-Pro deleted[388]: diskmanagement: [DMManager(PrivateMethods) clientConforms:error:]: currentThread=37395=0x9213 expectedThread=21003=0x520b
Oct  4 23:12:36 Weis-Mac-Pro deleted[388]: diskmanagement: [DMManager(PrivateMethods) clientConforms:error:]: currentThread=7691=0x1e0b expectedThread=21003=0x520b
Oct  4 23:12:36 Weis-Mac-Pro deleted[388]: diskmanagement: [DMManager(PrivateMethods) clientConforms:error:]: currentThread=26899=0x6913 expectedThread=21003=0x520b
Oct  4 23:12:49 Weis-Mac-Pro Installer[485]: ================================================================================
Oct  4 23:12:49 Weis-Mac-Pro Installer[485]: User picked Standard Install
Oct  4 23:12:49 Weis-Mac-Pro Installer[485]: Choices selected for installation:
Oct  4 23:12:49 Weis-Mac-Pro Installer[485]: 	Upgrade: "macOS High Sierra 10.13.6 Update"
Oct  4 23:12:49 Weis-Mac-Pro deleted[388]: diskmanagement: [DMManager(PrivateMethods) clientConforms:error:]: currentThread=10515=0x2913 expectedThread=21003=0x520b
Oct  4 23:12:49 Weis-Mac-Pro Installer[485]: Ignoring post-logout for non-restart install
Oct  4 23:12:50 Weis-Mac-Pro Installer[485]: Configuring volume "Hackintosh"
Oct  4 23:12:50 Weis-Mac-Pro Installer[485]: Free space on "Hackintosh": 64.03 GB (64026927104 bytes).
Oct  4 23:12:50 Weis-Mac-Pro Installer[485]: Create temporary directory "/var/folders/wz/jr_q7xy103n2r5gvszn205dc0000gq/T//Install.485QMwx55"
Oct  4 23:12:50 Weis-Mac-Pro Installer[485]: IFPKInstallElement (7 packages)
Oct  4 23:12:54 Weis-Mac-Pro Installer[485]: Package Authoring Error: PackageInfo bundle reference found without top-level bundle definition. Bundle will be skipped: <bundle id="*"></bundle>
Oct  4 23:12:57 Weis-Mac-Pro Installer[485]: PackageKit: Enqueuing install with framework-specified quality of service (utility)
Oct  4 23:12:57 Weis-Mac-Pro system_installd[528]: PackageKit: ----- Begin install -----
Oct  4 23:12:57 Weis-Mac-Pro system_installd[528]: Package Authoring Error: PackageInfo bundle reference found without top-level bundle definition. Bundle will be skipped: <bundle id="*"></bundle>
Oct  4 23:13:21 Weis-Mac-Pro system_installd[528]: PackageKit: Failed to clear quarantine on Apple-signed package PKLeopardPackage <id=com.apple.pkg.update.os.Combo10.13.6.17G65, version=1.0.0.0.1.1530695593, url=file://localhost/Volumes/Hackintosh/Users/man/Desktop/Video_Update_Files/macOSUpdCombo10.13.6.pkg#macOSUpdCombo10.13.6.pkg>: Item not quarantined (-1)
Oct  4 23:13:25 Weis-Mac-Pro deleted[388]: diskmanagement: [DMManager(PrivateMethods) clientConforms:error:]: currentThread=21015=0x5217 expectedThread=21003=0x520b
Oct  4 23:13:35 Weis-Mac-Pro deleted[388]: diskmanagement: [DMManager(PrivateMethods) clientConforms:error:]: currentThread=43783=0xab07 expectedThread=21003=0x520b
Oct  4 23:13:35 Weis-Mac-Pro deleted[388]: diskmanagement: [DMManager(PrivateMethods) clientConforms:error:]: currentThread=38175=0x951f expectedThread=21003=0x520b
Oct  4 23:13:40 Weis-Mac-Pro deleted[388]: diskmanagement: [DMManager(PrivateMethods) clientConforms:error:]: currentThread=15371=0x3c0b expectedThread=21003=0x520b
Oct  4 23:13:40 Weis-Mac-Pro deleted[388]: diskmanagement: [DMManager(PrivateMethods) clientConforms:error:]: currentThread=43783=0xab07 expectedThread=21003=0x520b
Oct  4 23:14:32 Weis-Mac-Pro system_installd[528]: PackageKit: Failed to clear quarantine on Apple-signed package PKLeopardPackage <id=com.apple.pkg.macOSUpdCombo10.13.6.RecoveryHDUpdate.17G65, version=1.0.0.0, url=file://localhost/Volumes/Hackintosh/Users/man/Desktop/Video_Update_Files/macOSUpdCombo10.13.6.pkg#macOSUpdCombo10.13.6.RecoveryHDUpdate.pkg>: Item not quarantined (-1)
Oct  4 23:14:32 Weis-Mac-Pro system_installd[528]: PackageKit: Failed to clear quarantine on Apple-signed package PKLeopardPackage <id=com.apple.pkg.macOSBrain, version=10.13.6.1.1.1530695593, url=file://localhost/Volumes/Hackintosh/Users/man/Desktop/Video_Update_Files/macOSUpdCombo10.13.6.pkg#macOSBrain.pkg>: Item not quarantined (-1)
Oct  4 23:14:32 Weis-Mac-Pro system_installd[528]: PackageKit: Failed to clear quarantine on Apple-signed package PKLeopardPackage <id=com.apple.pkg.SecureBoot, version=10.13.6.1.1.1530695593, url=file://localhost/Volumes/Hackintosh/Users/man/Desktop/Video_Update_Files/macOSUpdCombo10.13.6.pkg#SecureBoot.pkg>: Item not quarantined (-1)
Oct  4 23:14:32 Weis-Mac-Pro system_installd[528]: PackageKit: Failed to clear quarantine on Apple-signed package PKLeopardPackage <id=com.apple.pkg.EmbeddedOSFirmware, version=10.13.6.1.1.1530695593, url=file://localhost/Volumes/Hackintosh/Users/man/Desktop/Video_Update_Files/macOSUpdCombo10.13.6.pkg#EmbeddedOSFirmware.pkg>: Item not quarantined (-1)
Oct  4 23:14:32 Weis-Mac-Pro system_installd[528]: PackageKit: Failed to clear quarantine on Apple-signed package PKLeopardPackage <id=com.apple.pkg.FirmwareUpdate, version=10.13.6.1, url=file://localhost/Volumes/Hackintosh/Users/man/Desktop/Video_Update_Files/macOSUpdCombo10.13.6.pkg#FirmwareUpdate.pkg>: Item not quarantined (-1)
Oct  4 23:14:34 Weis-Mac-Pro system_installd[528]: PackageKit: Failed to clear quarantine on Apple-signed package PKLeopardPackage <id=com.apple.update.fullbundleupdate.17G65, version=1.0.0.0.1.1530695593, url=file://localhost/Volumes/Hackintosh/Users/man/Desktop/Video_Update_Files/macOSUpdCombo10.13.6.pkg#FullBundleUpdate.pkg>: Item not quarantined (-1)
Oct  4 23:16:08 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: [DMToolRecoveryPartition ensureRecoveryPartitionForVolume:]: inParams={
	    BlacklistCurrCPUDiag = 1;
	    Bless = 0;
	    DIAGDMGChunkFile = "/var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tmp.PT54DBKn/AppleDiagnostics.chunklist";
	    DIAGDMGFile = "/var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tmp.PT54DBKn/AppleDiagnostics.dmg";
	    DonorDiskUDSW = "disk0s2 Hackintosh";
	    OSXDMGChunkFile = "/var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tmp.PT54DBKn/BaseSystem.chunklist";
	    OSXDMGFile = "/var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tmp.PT54DBKn/BaseSystem.dmg";
	    RepairDonor = 0;
	    VerifyImage = 0;
Oct  4 23:16:08 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: [DMToolRecoveryPartition ensureRecoveryPartitionForVolume:]: donor disk's storage system is simple so it itself will be the donor
Oct  4 23:16:08 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: [DMToolRecoveryPartition ensureRecoveryPartitionForVolume:]: normalized donor: logical=0x7fe283b01cb8=disk0s2=Hackintosh=(iflvuuid=(null)) physical=0x700005caab50=disk0s2=Hackintosh=disk0s2 storage=(null)
Oct  4 23:16:10 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: [DMToolRecoveryPartition ensureRecoveryPartitionForVolume:]: at DoneCheckingDontPushWindowsOSPast4
Oct  4 23:16:10 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: [DMToolRecoveryPartition ensureRecoveryPartitionForVolume:]: aft look for Apple Diagnostics dmg+chunklist, err=(not fatal, just means no diags)=0 DMG=/var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tmp.PT54DBKn/AppleDiagnostics.dmg CHK=/var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/tmp.PT54DBKn/AppleDiagnostics.chunklist
Oct  4 23:16:10 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: [DMToolRecoveryPartition ensureRecoveryPartitionForVolume:]: and did we have to look around to find it (vs. just being passed-in) = usingOldDIAG=0
Oct  4 23:16:10 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: [DMToolRecoveryPartition ensureRecoveryPartitionForVolume:]: bef attaching and mounting dmg(s)
Oct  4 23:16:11 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: [DMToolRecoveryPartition ensureRecoveryPartitionForVolume:]: aft attaching and mounting dmg(s) err=0 ; note that if DidDiagSearch=0 and attach err then Diags will NOT be rebuilt (preserved)
Oct  4 23:16:11 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: [DMToolRecoveryPartition ensureRecoveryPartitionForVolume:]: checking for existence, and calculating sizes, of files in dmg(s)
Oct  4 23:16:11 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: [DMToolRecoveryPartition ensureRecoveryPartitionForVolume:]: CALC result phase 1/5 (after adding up logical file sizes in dmg + expected to create ourselves) requiredFileSpaceForRecoveryFilesULL=518949974 =Sbydiv=1013574 =MiBbydiv=494 =MBbydiv=518
Oct  4 23:16:11 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: [DMToolRecoveryPartition ensureRecoveryPartitionForVolume:]: CALC result phase 2/5 (converted to iomedia desired size) desiredMinRecoveryDiskIOMediaSizeULL=535727190 =Sbydiv=1046342 =MiBbydiv=510
Oct  4 23:16:11 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: [DMToolRecoveryPartition ensureRecoveryPartitionForVolume:]: CALC result phase 3/5 (after adding BootRoot iomedia allocation) desiredMinRecoveryDiskIOMediaSizeULL=636390486 =Sbydiv=1242950 =MiBbydiv=606
Oct  4 23:16:11 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: [DMToolRecoveryPartition ensureRecoveryPartitionForVolume:]: CALC result phase 4/5 (after applying minimum) desiredMinRecoveryDiskIOMediaSizeULL=650000000 =Sbydiv=1269531 =MiBbydiv=619 =MBbydiv=650
Oct  4 23:16:11 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: [DMToolRecoveryPartition ensureRecoveryPartitionForVolume:]: checking against recovery partition limit MAXimum
Oct  4 23:16:11 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: [DMToolRecoveryPartition ensureRecoveryPartitionForVolume:]: CALC result phase 5/5 (after applying MAXimum) desiredMinRecoveryDiskIOMediaSizeULL=650000000 =Sbydiv=1269531 =MiBbydiv=619 =MBbydiv=650
Oct  4 23:16:11 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: [DMToolRecoveryPartition ensureBooter:storage:phyUDS:logUDS:phyREF:logREF:copierForRecoveryFiles:hostOSXForBootRootFiles:recBSD:percentBegin:percentEnd:]: inMinSizeB=650000000 inSTORorNOT=(null) inPhyUDS=0x700005caab50=disk0s2=Hackintosh inLogUDS=0x7fe283b01cb8=disk0s2=Hackintosh inPhyREF=(null) inLogREF=(null) inLogMP=/Volumes/Hackintosh inFileCopier=0x7fe283905af0 inPct=16..95
Oct  4 23:16:11 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: [DMToolRecoveryPartition ensureBooter:storage:phyUDS:logUDS:phyREF:logREF:copierForRecoveryFiles:hostOSXForBootRootFiles:recBSD:percentBegin:percentEnd:]: existing conditions right after PHY=disk0s2: usedOrNotSpaceB=122880 hasBooter=0 booterPartID/disk=0/(null) booterLocB/SizeB=0/0
Oct  4 23:16:11 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: [DMToolRecoveryPartition ensureBooter:storage:phyUDS:logUDS:phyREF:logREF:copierForRecoveryFiles:hostOSXForBootRootFiles:recBSD:percentBegin:percentEnd:]: existing booter GUID=(nil if no booter)=(null)
Oct  4 23:16:11 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: [DMToolRecoveryPartition ensureBooter:storage:phyUDS:logUDS:phyREF:logREF:copierForRecoveryFiles:hostOSXForBootRootFiles:recBSD:percentBegin:percentEnd:]: existing conditions of PHY: disk0s2 loc=S=409640=B=209735680 siz=S=390625000=B=200000000000=N=200000000000
Oct  4 23:16:11 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: [DMToolRecoveryPartition ensureBooter:storage:phyUDS:logUDS:phyREF:logREF:copierForRecoveryFiles:hostOSXForBootRootFiles:recBSD:percentBegin:percentEnd:]: existing conditions of LOG: disk0s2 (could be whole so no loc) siz=S=390625000=B=200000000000=N=200000000000
Oct  4 23:16:11 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: [DMToolRecoveryPartition ensureBooter:storage:phyUDS:logUDS:phyREF:logREF:copierForRecoveryFiles:hostOSXForBootRootFiles:recBSD:percentBegin:percentEnd:]: READY TO DO CASE: case=Create_Carve_Simple spaceDeltaB=649879552 booterDeltaB=0 (adviceIfUnable=-69886)
Oct  4 23:16:16 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: [DMToolMountMisc _DAOperation_performsync_:disk:options:mountpoint:arguments:asEUID:asEGID:timeoutSec:dissenter:dissenterPID:]: [un]mount failed: err=-69888 un0mt1=0 timeout=0 dissenter=1 dissenterpid=485 dissenterstatus=49168=0xc010
Oct  4 23:16:16 Weis-Mac-Pro diskmanagementd[692]: diskmanagement: rawLaunch: execve(2) pid=692 /System/Library/Filesystems/hfs.fs/Contents/Resources/fsck_hfs -fn -l -x /dev/rdisk0s2 .
Oct  4 23:20:25 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: rawLaunch_block_invoke: waitpid(2) pid=692 ret/errno=692/35 status=0x00000000 exit=0
Oct  4 23:20:25 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: [DMToolRecoveryPartition ensureBooter:storage:phyUDS:logUDS:phyREF:logREF:copierForRecoveryFiles:hostOSXForBootRootFiles:recBSD:percentBegin:percentEnd:]: done fsck of donor slice; err=0
Oct  4 23:20:26 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: [DMToolPartitionMap editMapAtPartition:newSize:mode:optionSize:newEntriesRequested:formatNewEntries:newEntriesCreated:lmbrOption:percentBegin:percentEnd:partitionDataDelegate:]: inSliceDisk=0x700005caab50=disk0s2=Hackintosh inPct=26..34 inNewSize=199350120448(B)=389355704(S) inMode=AddRecoveryEntryDuringTargetShrinkOrNoChange inOptionSize=0(B)=0(S) inNewEntriesRequested=(null) inFormatNewEntries=0 inLMBROption=(null) inDelegate=(null)
Oct  4 23:20:26 Weis-Mac-Pro deleted[388]: diskmanagement: [DMManager(PrivateMethods) clientConforms:error:]: currentThread=15371=0x3c0b expectedThread=21003=0x520b
Oct  4 23:20:26 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: [DMToolPartitionMap editMapAtPartition:newSize:mode:optionSize:newEntriesRequested:formatNewEntries:newEntriesCreated:lmbrOption:percentBegin:percentEnd:partitionDataDelegate:]: outErr=0 outNewEntriesCreated=(
	    disk0s6
Oct  4 23:20:26 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: [DMToolRecoveryPartition populateBooter:verifyType:verifyMinSize:clearMode:copierForRecoveryFiles:hostOSXForBootRootFiles:statusReportingDisk:percentBegin:percentEnd:]: inPartitionUDS=0x700005caa7e0=disk0s6 inVfyType/MinSize=Apple_Boot/650002432 inClearMode=Format inRecCopier=0x7fe283905af0 inBRHostMP=/Volumes/Hackintosh inStatusDisk=0x7fe283b01cb8=disk0s2=Hackintosh inPct=35..87
Oct  4 23:20:26 Weis-Mac-Pro diskmanagementd[698]: diskmanagement: rawLaunch: execve(2) pid=698 /System/Library/Filesystems/hfs.fs/Contents/Resources/newfs_hfs -J -U 0 -G 0 -v Recovery HD /dev/rdisk0s6 .
Oct  4 23:20:27 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: rawLaunch_block_invoke: waitpid(2) pid=698 ret/errno=698/35 status=0x00000000 exit=0
Oct  4 23:20:27 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: [DMRecoveryFileCopier copyFilesToPath:atPercentBegin:percentEnd:]: inFilesDstPath=/Volumes/Recovery HD/com.apple.recovery.boot pct=37..81 ; mode=ERP
Oct  4 23:20:33 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: [DMRecoveryFileCopier copyFilesToPath:atPercentBegin:percentEnd:]: retErr=0
Oct  4 23:20:33 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: [DMToolRecoveryPartition populateBooter:verifyType:verifyMinSize:clearMode:copierForRecoveryFiles:hostOSXForBootRootFiles:statusReportingDisk:percentBegin:percentEnd:]: retErr=0
Oct  4 23:20:33 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: [DMToolRecoveryPartition ensureBooter:storage:phyUDS:logUDS:phyREF:logREF:copierForRecoveryFiles:hostOSXForBootRootFiles:recBSD:percentBegin:percentEnd:]: retErr=0 outDisk=disk0s6
Oct  4 23:20:33 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: [DMToolRecoveryPartition ensureRecoveryPartitionForVolume:]: final booter=recoveryDisk=disk0s6=0x700005caaa10=disk0s6=Recovery HD
Oct  4 23:20:34 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: [DMToolRecoveryPartition ensureRecoveryPartitionForVolume:]: at exit; err=0
Oct  4 23:20:34 Weis-Mac-Pro diskmanagementd[492]: diskmanagement: [DMToolRecoveryPartition ensureRecoveryPartitionForVolume:]: output recoveryDiskBSD=disk0s6 physicalDonorBSD=disk0s2
Oct  4 23:21:03 Weis-Mac-Pro system_installd[528]: PackageKit: Install Failed: Error Domain=PKInstallErrorDomain Code=121 "An error occurred while updating system extension information." UserInfo={NSLocalizedDescription=An error occurred while updating system extension information., arguments=(
	    "-update-volume",
	    "/Volumes/Hackintosh",
	    "-Installer"
	), NSUnderlyingError=0x7f9f059bd8c0 {Error Domain=kextcache Code=71 "(null)"}} {
	    NSLocalizedDescription = "An error occurred while updating system extension information.";
	    NSUnderlyingError = "Error Domain=kextcache Code=71 \"(null)\"";
	    arguments =     (
	        "-update-volume",
	        "-Installer"
Oct  4 23:21:04 Weis-Mac-Pro Installer[485]: Install failed: The Installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance.
Oct  4 23:21:04 Weis-Mac-Pro Installer[485]: IFDInstallController 6DC0 state = 8
Oct  4 23:21:04 Weis-Mac-Pro Installer[485]: Displaying 'Install Failed' UI.
Oct  4 23:21:04 Weis-Mac-Pro Installer[485]: 'Install Failed' UI displayed message:'The Installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance.'.
Oct  4 23:23:26 Weis-Mac-Pro deleted[388]: diskmanagement: [DMManager(PrivateMethods) clientConforms:error:]: currentThread=35875=0x8c23 expectedThread=21003=0x520b
#43135
Will there be some way to make a clean installation soon?
is that my video card gives a black screen and I can not even finish the installation, and since highsierra uses it natively from 10.13.4 onwards, I am waiting for a higher version than the current one to be able to return to my common applications ;)
  • 1
  • 2
  • 3
  • 4
  • 5
  • 14
