by: kegman
#49822
thanks for the reply. Got it working. Have 2 usb 2.0 headers on board, 1 was working other was not. the patches help... :clap:
#50051
I haven't been able to get anything to work. I ran the script, and it says it installed, I restarted and still only have USB 3 working. I could just be an idiot in how I'm doing things,.
Attached is my config, DSD, and reg files.
Thank you for any help in the right direction.
(2.87 MiB) Downloaded 46 times
by: AlGrey
#50179
@skydiver71903, use the manual version
#50475
I'm so ... happy !! I follow this and fix my problem about the bluetooth cannot catch. (Because the bluetooth needs the usb2.0)
Thank you so much!!
This is awesome....
Help me a lot, love you. :thumbup:
Mojave 10.4.1
AMD R7 2700X
RX580-8G
ASUS X470-F
#50613
But what to do if I don't have ryzen? I did try XLNUSBFix and rehabman's GenericUSB3 and my USB2 ports are still 12mb/s and USB3 not working at all. (there is voltage on USB3 ports because when conecting external usb3 drive, light on drive is on) Mojave 10.14.6
#50615
artouiros wrote:But what to do if I don't have ryzen? I did try XLNUSBFix and rehabman's GenericUSB3 and my USB2 ports are still 12mb/s and USB3 not working at all. (there is voltage on USB3 ports because when conecting external usb3 drive, light on drive is on) Mojave 10.14.6
Try this tweaked version of the kext, https://files.amd-osx.com/XLNCUSBFix.kext.zip
SleepingPanda liked this
#50617
Shaneee wrote:Try this tweaked version of the kext, https://files.amd-osx.com/XLNCUSBFix.kext.zip
Didn't work either. Actually I did open it, and it is the same version as in discord. I can see drive name but it does not show volumes on it. (im the one with that problem from discord)
#50826
Hi. After I used this script and removed USBInjestAll kext (or smt like that) my Strix SOAR soundcard won't work no more. it's a PCIE card but just after installing macOS it worked - now it's being recognized but it's not a sound output no more. What to do?
#50949
Hi AlGrey, thank your tut, I have CSR 4.0 USB Bluetooth, I tried your tut but USB Bluetooth can not work, USB Wifi WN-722N work well. Can you help me?
(5.43 MiB) Downloaded 30 times
  • 1
  • 9
  • 10
  • 11
  • 12
  • 13
