by: AlGrey
#43080
mrringht wrote: Wed Oct 03, 2018 7:41 am I try to patch the native audio for my hackintosh (ALC1220A) but failed (System will halt in booting after applied the patch). Attached files for your guys to help. Thank you!
boot in usb installer and open terminal
touch /Volumes/diskname/System/Library/Extensions
replace diskname with your partition name
Then :
kextcache -U /Volumes/diskname
And :
reboot
by: AlGrey
#43157
@mrringht, I already answered ...
by: bernek
#43164
I deleted Voodoohda.kext and tried to install the automatic script and I've got some errors and no audio anymore (either from onboard or HDMI).
Error logs and files
(6.32 MiB) Downloaded 35 times
by: AlGrey
#43167
@bernek, this config looks corrupted... get a copy from the EFI of your usb installer and try again.
by: bernek
#43178
AlGrey wrote:@bernek, this config looks corrupted... get a copy from the EFI of your usb installer and try again.
config.plist file ?
Did erase entire EFI partition and copied over from the installer same error I get.
(1.36 KiB) Downloaded 40 times
by: AlGrey
#43231
Try the manual method
by: bernek
#43232
Can you help explaining this a bit further ?
"Copy the one of the patch AZAL/D01A/D018 to HDEF from config_amd_hda.plist to your config.plist.
Under Kernel and Kext Patches in Clover configurator : add the "add 1022 vendor id" patch to your config.plist and add one of the "hardcoding 1022 ..." patch according to your audio device ID from step 2. "
This is my vendor id and product id: (VendorID,ProductID): 1022,1457
I don't understand the meaning of the text that I put in italics. Can you elaborate it a bit or make an example for me ?
Thanks !
by: AlGrey
#43233
Copy the azal to hdef patch from config_amd_hda.plist to your config.plist.
Add the 1022 1457 kexttopatch the same way..
by: bernek
#43246
AlGrey wrote:Copy the azal to hdef patch from config_amd_hda.plist to your config.plist.
I added everything correctly (I hope) and ran the semi automated version but I still get an error "No audio codec detected". I found where to copy the patches from one config to other (I believed it was more complicated but it was quite easy with Clover Configurator). Please take a look at my latest terminal output and config.plist ... In the terminal window you can see the steps that I did ...
Now I finally added everything correctly and the script moved further !
But now it asks me for a valid audioID what do I have to do now ?
"Agreement
The audio_cloverALC script is for personal use only. Do not distribute
the patch, any or all of the files or the resulting patched AppleHDA.kext
for any reason without permission. The audio_cloverALC script is
provided as is and without any kind of warranty.
File: audio_cloverALC-130.command_v0.5
Release Mode
EFI partition is mounted
System Integrity Protection status: disabled.
OK to patch
Your audio device (VendorID,ProductID): 1022,1457
Confirm Realtek ALC887 (y/n): y
ALC887 v_0x100302 (Current)
ALC887, Audio ID: 0 is not supported, continue (y/n): y
Vaild Audio IDs:
1 - 1/3/5/6 port Realtek ALCxxx audio
2 - 3 port (5.1) Realtek ALCxxx audio, Pink and Blue ports repurposed to outputs
Clover Audio ID Injection (y/n): y
Enter valid Audio ID (0 to exit): "
It seems to be working now but vaild Audio ID - 2 doesn't work as it should (at least for me) and if I run the script again I can chose 1 here ? there is no HDMI sound tho at all.
(3.86 KiB) Downloaded 37 times
  • 1
  • 3
  • 4
  • 5
  • 6
  • 7
  • 12
