by: AlGrey
#42688
did you save the output of terminal ?
by: RaJaKaR
#42690
AlGrey wrote: Sat Sep 15, 2018 7:21 pm did you save the output of terminal ?
Unfortunately I didn't. Should I run the script again?
by: AlGrey
#42694
Umm indeed Mic doesn't work.. anyone got his 3.5mm mic to work ?
#42698
AlGrey wrote:Umm indeed Mic doesn't work.. anyone got his 3.5mm mic to work ?
Don't have a mic to confirm but I can confirm the other post about the front audio port not working correctly. Also lost my HDMI audio.
by: AlGrey
#42702
Shaneee wrote: Sun Sep 16, 2018 9:05 am
HDMI will work if using whatevergreen.. otherwise radeondeinit requires DSDT editing
#42708
Yeah using Whatevergreen. Was working before. Must be the newer version of the kext. It's no big issue but I'll experiment.
AlGrey liked this
by: trus0und
#42998
Should this be applicable to Threadripper on X399 boards? Thanks!
by: AlGrey
#43000
trus0und wrote: Sun Sep 30, 2018 12:33 am Should this be applicable to Threadripper on X399 boards? Thanks!
Yes... it's Ryzen Threadripper so why wouldn't it work ?
#43003
AlGrey wrote:Yes... it's Ryzen Threadripper so why wouldn't it work ?
I am just messing around with the Native USB right now and wasn't sure if they were intended just AM4 or something like that. I will give this a go soon!
#43075
I try to patch the native audio for my hackintosh (ALC1220A) but failed (System will halt in booting after applied the patch). Attached files for your guys to help. Thank you!
(3.86 MiB) Downloaded 35 times
  • 1
  • 2
  • 3
  • 4
  • 5
  • 6
  • 12
