#42148
@AlGrey ,Thanks so much for all the help,I finally made it work.To me ,I must delete the DSDT in patched folder, and only use D018 to HDEF and AZAL to HDEF patch. If I use D01A and D018 patch both,I would never get into the system.After tried so many times ,I finally made it work.And this reply is to thanks all the help I get from this forum, and maybe useful for the others.Thanks again for your great work!
AlGrey liked this
by: RaJaKaR
#42660
I tried the automated process but it says no audio codec found
Outputs
(5.67 MiB) Downloaded 33 times
by: AlGrey
#42665
RaJaKaR wrote: Fri Sep 14, 2018 10:11 pm I tried the automated process but it says no audio codec found
run the script one more time or use the config attached
(2.57 KiB) Downloaded 64 times
by: RaJaKaR
#42673
AlGrey wrote: Sat Sep 15, 2018 12:02 am run the script one more time or use the config attached
Thank you very much for the reply,
I tried to run the sh again and this time I got the following result,
Agreement
The audio_cloverALC script is for personal use only. Do not distribute
the patch, any or all of the files or the resulting patched AppleHDA.kext
for any reason without permission. The audio_cloverALC script is
provided as is and without any kind of warranty.
File: audio_cloverALC-130.command_v0.5
Release Mode
EFI partition is mounted
System Integrity Protection status: disabled.
OK to patch
Your audio device (VendorID,ProductID): 1022,1457
/dev/fd/63: line 2142: syntax error: unexpected end of file
I tried with the config file you attached but got the exact same result
by: AlGrey
#42679
RaJaKaR wrote: Sat Sep 15, 2018 3:58 am
Agreement
Release Mode
OK to patch
try one more time
by: RaJaKaR
#42684
AlGrey wrote: Sat Sep 15, 2018 3:56 pm
Agreement
Release Mode
OK to patch
try one more time
Thanks again. This time it worked. I am getting audio output using "Internal Speakers" though I am using a headset connected to the rear 3.5mm port of the motherboard. is it normal? also I cannot get my microphone to work. How to fix it?
NB: I used "300" in Motherboard (300/200/x299/x99/Other = n)
by: AlGrey
#42685
RaJaKaR wrote: Sat Sep 15, 2018 6:34 pm Thanks again. This time it worked. I am getting audio output using "Internal Speakers" though I am using a headset connected to the rear 3.5mm port of the motherboard. is it normal? also I cannot get my microphone to work. How to fix it?
ummmmm why using 300 ? instructions are clear
For the codec choice : Answer "y" to all questions except for Motherboard (300/200/x299/x99/Other = n).
3.5mm jack on mobo is called Internal Speakers yes.
Is it a usb microphone ?
by: RaJaKaR
#42687
AlGrey wrote: Sat Sep 15, 2018 7:14 pm
No. its the mic attached to my headset with separate 3.5mm pink jack
  • 1
  • 2
  • 3
  • 4
  • 5
  • 12
