#45143
Hi, this new method is really better, thank you.
I got everything working besides the microphone(front and back).
I tried different layouts but it didn't work.
MacOS 10.13.6
MOBO: Asrock Taichi x370
Thank you very much for helping
by: AlGrey
#45145
ya mic is an issue. no fix yet
#45155
Let me know if you need help testing when you have any progress with mic.
AlGrey liked this
#45212
@AlGrey,Once I rebuilt cache(using kext wizard then run command touch /Voulmes/User/System/Library/Extensions and kextcache /Voulmes/User/), MacOS would stuck on booting.It seems like autofs fail.
I had to boot in USB install and run command touch /Voulmes/User/System/Library/Extensions and kextcache /Voulmes/User/ again. But still no output device in sound settings .
by: AlGrey
#45233
@forwuwenkai, check first post to see how to report errors
#45340
Latest AppleALC method works flawless with my Ryzen setup! Many thanks for this!!
#45352
Anybody have mic(front or rear) working with AppleALC method?
#45353
immortalx wrote:Anybody have mic(front or rear) working with AppleALC method?
No, AlGrey is looking into it.
  • 1
  • 8
  • 9
  • 10
  • 11
  • 12
