#41916
You need to apply the HDEF patch in Clover and reboot before running the script.
Copy the AZAL and D01A to HDEF patch from config_amd_hda.plist to your config.plist.
by: AlGrey
#41980
@Yaoxl, run post install (XLNC or AMD) from usb installer to rebuild cache and fix permissions
by: AlGrey
#42093
@wang0315abc, I don't see the audio device in IOREG. Make sure audio is enabled in BIOS and rebuild your cache with
sudo touch /System/Library/Extensions
sudo kextcache -Boot -U /
sudo reboot
Then send me your IOREG dump.
#42099
@AlGrey,thanks so much for the help.It's really wired that I also can't find my audio device, the only place I can find HDEF is as the pic shows.And also the vendor id I can see is the same with you, but the device id isn't 1457,is 1454 instead...I take different settings in the bios for several times, but all turns out that if I go to win10,the audio is alright, so I think maybe is not a hardware or bios setting thing...Is there anything I can do to fix this?Thanks again
屏幕快照 2018-08-05 15.04.24.png (341.51 KiB) Viewed 728 times
by: AlGrey
#42104
report with all the files requested ..
by: ydeng
#42108
wang0315abc wrote: Sun Aug 05, 2018 12:20 pm @AlGrey,thanks so much for the help.It's really wired that I also can't find my audio device, the only place I can find HDEF is as the pic shows.And also the vendor id I can see is the same with you, but the device id isn't 1457,is 1454 instead...I take different settings in the bios for several times, but all turns out that if I go to win10,the audio is alright, so I think maybe is not a hardware or bios setting thing...Is there anything I can do to fix this?Thanks again
汪伟,that is not an audio device
Device 1022:1454
Name: Family 17h (Models 00h-0fh) Internal PCIe GPP Bridge 0 to Bus B
Your dsdt/ssdt modification is incorrect.
by: AlGrey
#42140
@wang0315abc, ok so I updated the script and the HDEF patch for your device (D018 to HDEF: 44303138 -> 48444546).
(13.95 KiB) Downloaded 60 times
  • 1
  • 2
  • 3
  • 4
  • 5
  • 12
