by: michael_1985
#41652
AlGrey wrote: Thu Jul 12, 2018 8:21 pm @michael_1985, share your DSDT and dump your IOREG
You mean to send IOREG file or some screenshot?
(8.39 MiB) Downloaded 39 times
by: AlGrey
#41663
You still have genericusbxhci.kext..
by: michael_1985
#41665
No i deleted them all. from clover efi folder and from both extensions folders.
by: AlGrey
#41676
@michael_1985, Wrong.. Redo step 1 to 3.
Screen Shot 2018-07-14 at 3.49.02 PM.png (247.08 KiB) Viewed 692 times
by: michael_1985
#41697
Hmm, i uploaded the ioref file when i put kexts again cause usb not work.. :p i repeat the steps and i find this... usb 3 & usb 3.1 works but with speed of usb 2 (same problem as Shaneee). only front usb 3 work with the right speed. also for a strange reason, the usb sound card (steinberg ur12) does not work on any usb 3 port :(
by: AlGrey
#41698
@michael_1985, viewtopic.php?f=53&t=4855. .. edit PTXH and HXC0 and add clover patch (first comment in the thread)
Here is your DSDT. Just add the clover patch from previous link
(12.14 KiB) Downloaded 40 times
michael_1985 liked this
by: michael_1985
#41712
@AlGrey all its ok now. only problem my sound card not work in usb3 port but its ok. thanks dude :) <3
by: AlGrey
#41713
:thumbup:
your device doesn't support 3.0.. https://www.steinberg.net/en/products/a ... /ur12.html
by: michael_1985
#41719
if i use genericusbxhci.kext it works in usb3
by: SangieWolf
#41857
OMFG! I LOVE YOU! I can now use my Crypto license dongle o: It wasn't working before.
