#40337
Open Terminal and enter:
diskutil list
make note of the device entry for Recovery HD.
Then enter the following commands in Terminal:
cd /Volumes
sudo mkdir /Volumes/Recovery\ HD/
Now to mount the Recovery HD to get it ready. Replace /dev/disk0s11 with the device entry for YOUR Recovery HD:
sudo mount -t hfs /dev/disk0s11 /Volumes/Recovery\ HD/
Enter the following commands to move a working prelinkedkernel to the Recovery HD:
cd /Volumes/Recovery\ HD/com.apple.recovery.boot/
sudo rm -rf prelinkedkernel
sudo cp /System/Library/PrelinkedKernels/prelinkedkernel /Volumes/Recovery\ HD/com.apple.recovery.boot/
sudo touch prelinkedkernel
Now you can boot into the Recovery partition from Clover, its just like the Installer interface. You can run Terminal, Disk Utility and do a Time Machine restore (HighSierra) from it. Just don't try to reinstall the OS from it.
Screen Shot 2018-05-14 at 4.23.24 PM.jpg (134.77 KiB) Viewed 235 times
