#40081
The syntax is:
diskutil list
diskutil unmountDisk /dev/disk5
 sudo dd if=nameofdmg of=/dev/rdisk5 bs=1m
Replace rdisk5 with the device id of your USB. You need to be in the same directory as the dmg your copying.
#40114
The video is not available :roll: (EDIT:OK now!)
Do you know if it works on Linux? Have never found a way to create a bootable usb drive without transmac or inside a virtual machine
#40115
Don't know linux, so you'd have to figure it out. I updated the video and it should play now
#40121
To be honest I haven't found a solution ,since years.
All the info on the net is misleading ,since most of the people think that it's a simple dmg to iso process .
I tried on windows a nice free utility in the past "Win32 Disk Imager", but didn't work. If dd works on Linux I'll post here :)
Thanks for the tutorial!
