by: Serenity
#23655
I get : "Illegal instruction: 4" when trying to repair
So I tried kext wizard to repair and rebuild. It said it didn't I didn't see any new files in prelinkedkernel before I rebooted. It's rebooting as I typed this so I'll inform ya.
It broke......
by: andynm
#23659
Pgkgaming wrote: Sun Jul 16, 2017 10:11 am It broke......
Download the latest kernel for El Capitan and put it on the installer USB stick (or another one) then do this:
viewtopic.php?f=24&t=80
You can skip the /Extra folder but remember to also copy the System.kext to /S/L/E before deleting the prelinkedkernel and recaching the kexts
by: Serenity
#23663
it was for yosemite 10.10.1 to 10.10.5 Shaneee pointed to this tutorial just use to appropriate files
#23684
@Pgkgaming, What isn't working? Yosemite is easier to update than El Cap or Sierra.
by: Serenity
#23730
I replaced all the files that I had according to the guide and it just went into a boot loop. When I ran the commands they didn't do anything either
by: Norton287
#26806
Kextcache-u / caused an instant crash for me. Used kext utility worked great.
by: redor
#27073
Hello I'm trying to install the combo update but it does not allow me to install it. It says I should restart the computer so that installation can continue. I downloaded the update from the link given in this post.
by: Norton287
#27075
@redor let it reboot, it's a soft reboot and will do the install. Once the installs done boot of your USB installer and run postinstall again.
by: redor
#27079
Norton287 wrote: Fri Sep 15, 2017 6:58 pm @redor let it reboot, it's a soft reboot and will do the install. Once the installs done boot of your USB installer and run postinstall again.
I did as you told me to. The problem is now it only boots using USB or Safemode otherwise it just says "Still waiting for root device" :(
by: Norton287
#27081
redor wrote:I did as you told me to. The problem is now it only boots using USB or Safemode otherwise it just says "Still waiting for root device
And you redid post install copying shaneees new kernel, deleting the prelinkedkernel and running repairpermissions and then kextcache-u /?
  • 1
  • 4
  • 5
  • 6
  • 7
  • 8
