by: Maidenman
#7508
Oh, that's the case. In worst scenario I will do another installation then. I know the drill so it should be quick ;)
#7511
The update should still work fine on ASUS boards. You'll need to apply the USB fix again if you've replaced the originals.
by: Maidenman
#7516
Yeah, but I cant even boot the system now :/
#7517
Did you replace the kernel before rebooting? Boot with -v UseKernelCache=No
by: Maidenman
#7518
Yes I did. I will try those boot flags today. I'm thinking to replace kernel again via terminal as my last hope.
#7530
Most of the time even when the kernel has been replaced the reboot happens because of the caches and prelinkedkernel. Disabling the kernel caches should bypass that.
by: Maidenman
#7552
YES! That works! I have 10.11.6 now 8-)
Did I mentioned you are AWESOME? :thumbup:
#7555
It should have force rebuilt the cache in doing that so it should now boot normally :thumbup:
by: camerowo
#8562
Digging up a semi old thread, sorry!
I followed all of your instructions and for whatever reason, chameleon can't find kernel at all, I've even tried using UseKernelCache=No and it panics after a minute and restarts!
I'm reinstalling to see if I can try to fix the issue. Any suggestions?
#8575
camerowo wrote:Digging up a semi old thread, sorry!
Did you replace the kernel? If you've still got the USB installer you can boot into it and use terminal to copy the kernel again like you did after you installed.
  • 1
  • 2
  • 3
  • 4
  • 5
  • 6
  • 8
