#37166
Hello, when a load my usb device, then i load High Sierra I wait like 1 minute and I have something like this after 1-2 minutes... : Image
My sys specs are : Cpu : Amd A8 5500B
Gpu : Ati Radeon HD 5450
Thanks.
#37167
Do you have USB 3.0? If so boot using 2.0 and when the scrolling text starts move the USB to a 3.0 port.
#37172
Did you start in a USB 2.0 then move to a 3.0 as soon as the scrolling text started?
#37178
When that screen appears then try another USB 3.0 port. I've moved the port at that screen and it still continued.
#37182
Are you using a front USB port or rear?
