#38165
AlGrey wrote:@ronaldo9_r9, intel chips are not supported
Thanks for the answer. How do i undo the changes.
#39240
@luxi.fang, you don't need the patch when you use my solution https://forum.amd-osx.com/viewtopic.php ... 836#p36836
#40824
JohnSmith wrote: Wed May 30, 2018 4:25 pm Hi,
I've used this to mostly success but I'm having trouble connecting my mouse (standard non Apple one) and my Magic Trackpad 2. I was wondering if you could help?
Thanks
Go to here
https://developer.apple.com/download/more/
Download the additional tools for xcode. Contains two Bluetooth troubleshooting tools.
#40827
Thanks for that, but unfortunately it is only showing me a generic "(null) (Handle: 0xD) connection failed, status: 0x04". Personal Hotspot on my iPhone and bluetooth speakers are fine. I think it might be the kext. I'm going to keep trying to investigate.
#40828
JohnSmith wrote: Wed May 30, 2018 5:08 pm Thanks for that, but unfortunately it is only showing me a generic "(null) (Handle: 0xD) connection failed, status: 0x04". Personal Hotspot on my iPhone and bluetooth speakers are fine. I think it might be the kext. I'm going to keep trying to investigate.
Ok
