#35947
DEPRECATED : use this instead viewtopic.php?f=24&t=4986&p=42056
You want to download the following zip and extract it to your desktop. Do not rename it.
http://bit.ly/BTRyzen
Then open the folder and double click on the file labeled bluetooth. Then when asked enter you macOS install name and your password. It will then backup and copy the files automatically, then do a repair and rebuild the prelinkedkernel.
This should hopefully resolve your bluetooth issues.
#36836
What is even better.. GenericUSBXHCI.kext for the Chipset controller (id 0x43bb1022) and native support for the 4 USB ports controlled by the CPU. My BT dongle is working OOB now using a CPU controlled USB port.
(58.16 KiB) Downloaded 134 times
#37103
um..
I trying your patch but it is not work...
Kext with invalid signatured (-67062) allowed: <OSKext 0x7f903f92fa90 [0x7fff91d49980]> { URL = "System.kext/ -- file:///Volumes/HighSierra/System/Library/Extensions/", ID = "com.apple.kernel" }
Kext with invalid signatured (-67013) allowed: <OSKext 0x7f903f806090 [0x7fff91d49980]> { URL = "CSRHIDTransitionDriver.kext/ -- file:///Volumes/HighSierra/System/Library/Extensions/IOBluetoothFamily.kext/Contents/PlugIns/", ID = "com.apple.driver.CSRHIDTransitionDriver" }
kxld[com.apple.driver.AppleBluetoothMultitouch]: The following symbols are unresolved for this kext:
kxld[com.apple.driver.AppleBluetoothMultitouch]: IOWorkQueue::withCapacity(OSObject*, unsigned int, IOWorkQueueOperationMode, bool, char*)
Link failed (error code 5).
Prelink failed for com.apple.driver.AppleBluetoothMultitouch; omitting from prelinked kernel.
KernelCache ID: 76A9363DBE753CF0F6354013A11F39D7
kernel cache rebuild failed in 13.2
#37345
dygkset wrote:um..
You got a KenrelCache ID so it worked, prelink failed for BluetoothMultiTouch.kext because of a version difference. It only affects you if you're using a magic trackpad.
#38052
Does this work with inbuilt wifi and bluetooth on the motherboard. I have x370 taichi mobo.
I am running ahs sierra v2 with xlnc scripts.
Sent from my SM-N950F using Tapatalk
#38061
Norton287 wrote:Should work with any compatible bluetooth adapter
Thanks Norton. How do I repair and rebuild prelinkedkernel. Is it with kext wizard?
#38094
Kext Utility will rebuild the prelinked, kext wizard only repairs permissions
#38161
Thanks Norton. I have tried what you have said but bluetooth is still not working. I get this in system report when I click on Bluetooth HCI
Bluetooth HCI:
  Product ID:	0x0aa7
  Vendor ID:	0x8087  (Intel Corporation)
  Version:	0.01
  Speed:	Up to 12 Mb/sec
  Location ID:	0x00900000 / 1
  Current Available (mA):	500
  Current Required (mA):	Unknown (Device has not been configured)
I have X370 Taichi mobo that has wifi and bluetooth inbuilt.
Thanks
#38163
@ronaldo9_r9, intel chips are not supported
