#39499
kokos wrote:I have the amd fx 8370e and I set the buss ratio=33 and the cpu frequency3300 and the buss speed200000 and it goes sloes!any solution?thanks a lot!!!
Busratio should be 17
#39501
Try with just bus ratio just now.
#39505
i try it !i think now its with better performance,tomorow i will check the motherboard bios setting because at windows cpuid the cpu timing is goint from 3.3 ghz to 1,6,i thinat bios is in auto the cpu timing,maybe is this the problem?
#40164
busratio isn't good idea to long term usage.
For examply my CPU working on 7 ~ 22 busratio. on 17 clock it's on 3500Mhz . Now try working on that whole one day.... Normal CPU don't work in 100% / Turbo Speed all the time. That's why.
This setting it's good to test our speed / configurator hackintosh. Nothing else. Somebody with better temp cooler , can stay with it longer.
#40170
sajmonella9 wrote: Fri May 11, 2018 12:26 pm busratio isn't good idea to long term usage.
This is used to resolve audio issues not for over clocking.
#40317
I have audio video sync problems' try bus ratio 17 and the synch is not good and I have a pop on sound every 5 seconds.i use hdmi and I use and my headphones but the problem is the same!
I try and the vga ,the same problem, when I play a video for 5 seconds its ok but when it pops its out of synchs ,the same at the quick timeplayer!
#40320
kokos wrote: Mon May 14, 2018 10:17 am I have audio video sync problems' try bus ratio 17 and the synch is not good and I have a pop on sound every 5 seconds.i use hdmi and I use and my headphones but the problem is the same!
Try just setting the bus speed in clover configurator on the CPU tab.
