#35067
thanks!
that never happened
my clover never showed me what you point out in your tutorial as I never saw this: Boot macOS Install from YOURINSTALLPARTITION
My Clover shows me and calls all the discs with their name never adding "install" it doesn't see the partition you're referring to
are there options in clover that might prevent that from happening?
#35068
Not really it sounds like the temporary partition isn't being created. I'd upgrade through 10.13.2 installer, just follow the tutorial and constantly boot off the install on reboots until the very end.
#35507
Hey guys ran into a issue I cant seem to find a solution for. Been happily using Sierra but decided to update to High Sierra 10.13.1 but I cant get it to boot without the USB installer.
I've managed to installed clover and followed the tutorial step by step but whilst booting via clover I get "APPLEACPICPU" timeout and finally it boots to a black screen with just the cursor. After which clicking makes the cursor disappear and then nothing can be done. Any help please?
I have also copied the Extensions file from my USB's EFI to my install locations EFI/Other folder because I dual boot Win 10.
#35509
My USB installer doesnt have a 10.13 folder in it, I downloaded the image from the downloads section.
I'm redownloading the image from the first post and will try again, will update afterwards, thanks.
#35653
Hey quick update, after a load of messing around I got it working. for some reason clover dislikes UEFI on my system, it hangs on OsxAptioFix2Drv. I tried removing this and installing OsxAptioFixDrv instead but hangs on the same error.
However I decided to instal clover for Legacy instead and it now boots into the OS fine with just 1 little niggle. Clover spends a good minute or 2 scanning for entries on boot. Afterwards it boots fine, anyway to fix this?
#35727
In clover configurator you want to set scan to custom in the GUI tab like this:
Screen Shot 2018-01-01 at 7.31.03 AM.jpg (124.46 KiB) Viewed 597 times
  • 1
  • 12
  • 13
  • 14
  • 15
  • 16
