#34988
Yes off course I would do it. But now the installation went just like you wrote in the tutorial.
I’ve managed to goto the Terminal after booting from the USB.
Yesterday I tried 3 times, and 3 times it failed.
The far I went was getting the message OsInstall.mpkg corrupted can’t install
Sorry for wasting your time :eh: :crazy: :thumbup: :thumbup:
#34996
It upgraded your drive to APFS, here's where to download and install it: https://www.tonymacx86.com/threads/how- ... ds.236103/
copy it to the root of your USB and boot to Terminal and enter the following commands:
diskutil list (look for your USB and your harddrives EFIs and note the drive)
diskutil mount EFI /dev/YOURFIRSTEFI
cd /Volumes/EFI/Clover/drivers64UEFI
cp -rf /Volumes/HighSierraAMD/apfs.efi ./
ls -al (check make sure it copied)
Repeat the process for the USB so it has it to see your drive.
Then reboot and see if clover sees it and the USB as well.
vitorlage liked this
#34998
I'm not sure what I'm doing wrong but it fails to update.
I'm upgrading an external USB MacOs with a clone of my system.
My system is on a Nvme drive so it wouldn't be seen by the USB installer to run script 1
I did these steps:
1. Download the High Sierra 10.13.2 INSTALLER from the app store
2. Let the installer run from the MacOSUSB system, and reboot
3. Once the installer reboots you need to boot off the USB installer, let the installer load. Once the installer loads select Terminal from the Utilities menu
4. Once Terminal loads enter: sh /Volumes/HighSierraAMD/AMD/setup_run
5. Once the menu loads you want to Select option 1, enter your hard drive name and let it do its thing
6 . Once Pre-Install is done choose 11 to reboot
7. Now you want to boot off the macOS Install from macOS partition or whatever you named your install partition
And here I get into trouble.:
- after script 1 has run on the proper MacOSUSB disk I reboot from such disk and Windows runs. Meaning the bios selects my other sata disk with windows
- if I boot from the EFI of such MacOSUSB I simply boot the system and no installer runs
- if I boot from the USB installer and then select MacOSUSB as above: it simply boots the system up
What am I doing wrong?
#35002
Norton287 wrote:It upgraded your drive to APFS, here's where to download and install it: https://www.tonymacx86.com/threads/how- ... ds.236103/
It worked almost like a charm. It took me some time to figure out what the right command to use instead of
I used
diskutil mount /dev/YOURFIRSTEFI
e.g
diskutil mount /dev/disk0s2 — my Mac HDD
and
distil mount /dev/disk3s2 — my USB Installer
Many thanks to this enormous guy Norton :D :thumbup:
Norton287 liked this
  • 1
  • 11
  • 12
  • 13
  • 14
  • 15
  • 16
