#34917
I'm having issues upgrading to 10.13.2
After running the installer within 10.13.1 I rebooted from the USB drive...but the installer I used a few days ago to install it all fails to load.
My system is on a Nvme drive I guess the whole procedure would fail as the installer is on 10.12.0 and it odesn't see the Nvme drive
Can I at least disable the setup routine that is waiting for the Nvme drive to boot?
#34920
this one? SierraAMD V5.2
#34922
No it's in the first code box in the instructions at the top where it talks about enoch bootloaders
This is link there:
 https://mega.nz/#!B3gnATRY!wQ8JwVJ-ZyLbBoEif7bGWzSXQq6xvnhkFivfMQ8XrLk
#34923
thanks..
tricky though as the only installer that actually booted up on my system out of AMD v something and XLNC was the one of this post
HighSierraAMD for Radeon?
Does it matter I have Nvidia_
not sure if it's just me but it's easy to stop an installation
just get rid of the nvram.plist apple writes into the EFI and that's it...
:D I have time now to figure out the USB key from the system itself
Is there a mac software rather than Transmac to copy the image?
Thanks
I created the USB drive using the image you suggested.
BUT that USB drive doesn't boot on my machine.
It hungs.
BUT IF I boot using my clover EFI, the one on my main hard disk, and select the just created USB drive THEN it boots into the 10.13.1 installer.
Would that be alright to proceed with the 10.13.2 update?
It should, right?
Thanks.
#34967
The update fails.
When I run the script the first time and then select option 1 for Pre Install the script tries to copy something into a folder that doesn't exist:
MacOS disk/macOS Install Data/ a folder that contains "locked"
there are no folders containing the locked word in my macOS Install Data folder
#34972
maxshq wrote:My HD7770 no siginal.
Add -radpg=15 to your boot flags
zzmadd wrote:The update fails.
The installer puts that folder there, the script checks if that folder exists and if it doesn't it doesn't allow preinstall to occur.
The installer puts it there during first install portion when you first download and run it.
#34983
Norton287 wrote: Thu Dec 21, 2017 1:01 pm
it dont work,but i used "-radvesa" boot args have siginal.but.......
screenshot
screenshot
  • 1
  • 10
  • 11
  • 12
  • 13
  • 14
  • 16
