#31493
Follow the tutorial here for installing V5 to the letter including copying the clover file to your EFI folder
  • Make sure you're not using a VGA connection
    Change ports on your video card
    Unplug any second third or fourth monitors
    If you didn't copy the clover files from the root of your harddrive you're a pussy so stop being a pussy and copy them to your EFI folder. It contain NVIDIAGraphicsFixUp and Lilu.
    Enable CSM and UEFI booting, if you can't boot CSM or UEFI I have a version of 5.2 with enoch.
