by: Norton287
#31410
Once you install 10.12.5, the app store will prompt you with wanting to install a Security Update. Go ahead and click install. It will download it and reboot into the installer. Once the installer is done it will reboot the whole computer. Have you V4.5 USB installer plugged in and boot off it to the installer so you can run post.sh. Once you're at the installer, click on Utilities and choose Terminal. Once Terminal opens you want to enter the following commands:
 cd /Volumes/SierraAMD/PostInstall
sh post.sh
enter the volume name you gave 4.5 when you first installed it and press enter
Let Post.sh run and once finished reboot removing the USB and boot into your hard drive and everything should be ok.
