by: Dann
#39450
This fix did the trick for me /ryzen 5 1600, gtx 650ti boost, 16gb ddr4, samsung evo 960 nvme/. Magic mouse and keyboard connected and work nice also in BIOS. But only issue is now I can't put my hack to sleep. Whenever it tries to go to power nap (I guess) like 1 minute after sleep it simply turns on again and monitors turn on as well.
by: vinhbaoabc
#39658
@Norton287
I disable SIP then my PC can not reboot.
I must using linux to re-edit config.plist and install 4 kext files without disabling SIP.
Now the bluetooth with mini usb bluetooth orico ok. I can connect it to keyboard, trackpad and speaker but
i can not restart pc.
It allways show on restart process and i must hit restart button on my case to force restart:
Waiting for remote debugger connection
kdp_poll : no debugger device
Can you tell me how to fix this ?
thanks.
by: leog
#40345
@Norton287
The process for this fix is:
1.Disable SIP
2.Restart
3.Install Kexts
4.Restart
5.Enable SIP
Or i got the process understood wrong?
by: leog
#40358
@Norton287
Fixed my bluetooth, made it to pair my headphones but my mx master 2s mouse doesn't pair.
And when i try to pair it, something messes up with the library/preferences/com.apple.bluetooth.plist and i need to delete it and restart in order for my headphones to work again.
when grep bluetooth i have these:
   78    2 0xffffff7f826a9000 0xbd000    0xbd000    com.apple.iokit.IOBluetoothFamily (4.3.6f3) A6C72B5A-8080-3BB4-9524-5894106CB31C <19 7 5 4 3 1>
   79    1 0xffffff7f82e1f000 0x21000    0x21000    com.apple.iokit.IOBluetoothHostControllerUSBTransport (4.3.6f3) B21D24ED-B19B-34E3-8912-2C79B9790DAD <78 58 12 11 7 5 4 3 1>
   80    0 0xffffff7f82e40000 0x3000     0x3000     com.apple.iokit.CSRBluetoothHostControllerUSBTransport (4.3.6f3) 2FD16D85-7547-3E9C-9BFC-3FD312109D86 <79 78 58 7 5 4 3>
   98    0 0xffffff7f829df000 0xa000     0xa000     com.apple.iokit.IOBluetoothSerialManager (4.3.6f3) 30EB1A50-8927-364F-8488-BB07055104BD <97 7 5 4 3 1>
SIP enabling on my High Sierra install didn't allow me to boot to desktop so i enabled the parameters on the clover config on boot to desktop , then installed the kexts , restart bluetooth works, sip back to enabled, restart.
by: Norton287
#40359
Download the Bluetooth support tools in this zip, it will help you troubleshoot connection problems.
https://drive.google.com/file/d/1iEmWAfGO2F8HttFKZtQX6YgOIptnAoK1/view?usp=sharing
by: leog
#40439
@Norton287
Thanks for the help.
Didn't make it to connect the mouse, but my bluetooth works fine so i am guessing incompatibility with the dongle and mx master 2s.
Only issue i am concerned is that i lost the ability to sleep the hack. Although not tested heavily, previously sleep was working.
Does it have to do with the bluetooth fix?
by: Norton287
#40441
Bluetooth could be holding it up, check Console app logs for what is holding it up. Could drill down and isolate the issue.
