by: frle10
#24119
Hello,
I have one question. I want to run a Mac OS X alongside my existing Windows 10 Enterprise OS. Is that somehow possible and how would I do that? And also, could it be possible to install my Mac OS X on an external HDD which I have? It's capacity is 1TB.
Thank you all! :)
by: spykor
#24120
Yes, but...it's gonna be slow.
by: frle10
#24124
I see. Even if it is USB 3?
And what about just installing it parallel to my Windows OS? On an internal HDD?
#24186
It's always better to install to a separate HDD if you install internally. You can try installing to the external. I used to have a Snow Leopard install on an external using USB 2.0 and it was useable :thumbup:
