#1675
So a new kernel has been released which gives better support and less errors but how to update your current one?
First download the new kernel.
Then navigate to /System/Library/Kernels and replace the current one with the new one you just downloaded.
Now navigate to /System/Library/Caches and delete the following folder, com.apple.kext.caches
Now go to /System/Library/PrelinkedKernels/ and delete the file prelinkedkernel
Once you've copied the kernel open Terminal and run the following command,
sudo kextcache -u /
This is the process I use :thumbup:
qmastery, Sundhar88 liked this
by: Jordi
#1679
upsss man something is not working exactly in the introduction can you revise what error is going i'm here System/Library/Caches/com.apple.kext.caches/Startup/kernelcache -K
-bash: System/Library/Caches/com.apple.kext.caches/Startup/kernelcache: No such file or directory
#1680
Ok wasn't sure if that would work on all systems. I've updated the post.
by: Jordi
#1682
no i don't see somethink new, i think more that it can go to slow-down menu. I start the new kernel and try to open the application menu then it may start showing slow... Can someone confirm if the new kernel is more powerfull. thanks
#3068
Post updated.
