#24015
moOXiii wrote: Fri Jul 21, 2017 4:28 pm hi. I gave up... it was stuck for minimum 12 hours. So I've plugged in a further hdd only for mac. But now I can't even access the installer anymore...
You need to move your mouse while it's installing ( don't stop until it's done.) .
For me takes 10-11 min to install it while moving my mouse.
#24021
or just keep something on both keys (windows+L) it constantly opens the log. which keeps the system awake.
#24126
in Dos??
can really nobody help me? :/
#24187
Just leave the installer running. It can take anywhere between 20 mins to 4 hours in some cases.
#24206
im still stuck at This screen
BIOS Setting 2
BIOS Setting 2
#24209
How did you get to that? What happens if you press a key?
#24212
Then it freezes... the symbol at the bottom is blinking. When i press a key it stops
#24216
Did you get Sierra installed?
#24299
Negative
#24315
Do you have ACHI enabled instead of IDE?
