#23802
first of all you will need to follow this guide (thanks to vio)
viewtopic.php?f=24&t=1693
After you have set everything up (I recommend using clover as it is easier to set up) if you have problems with booting with clover use this config.plist file that will set up clover to boot without any problems granted you have Nvidia drivers installed and running a compatible AMD processor
If you run into any other problems please feel free to ask and I will help out! It took me 5 days of trial and error to get working! p.s use iMac 14,2 in SMBIOS or Mac Pro 5,1
#23858
Thanks for ur fast reply. I'm already stuck. The USB Installer is not booting. I'm choosing to boot USB first, then it's trying to but instantly it skips and boots into windows. What's the problem here?
#23864
are you using the sierraAMD usb?
#23872
Yes and I started the installer but it Stucks somehow at 15 minutes remaining... I've tried again but it's the same. The hdd led isn't even running... I'm waiting since an hour now
#23921
Trust me it can take anywhere from 12 minutes to 3 hours. I think mine took roughly an hour and a half. So trust me it's working. What I did to make sure my hd didn't goto sleep was put something heavy on the alt key and L key to keep everything awake and watched tv.
#23994
hi. I gave up... it was stuck for minimum 12 hours. So I've plugged in a further hdd only for mac. But now I can't even access the installer anymore...
#23996
Are there any errors when starting the installer?
#23998
It's the CPU info screen before Darwin bootloader comes... (press a key to continue) i press it and it freezes
And no. There are no messages coming
#24007
Is this on the HDD that you replaced the other one with?
#24009
i didnt replaced a HDD, ive added a 3hrd one. SATA 120. Im still trying to boot from the USB Stick...
When i plug the USB Stick into the pc, then it "boots" some gpt messages. After that, a new screen appears with CPU INFOS where i have to press anything to continue. But then nothing happens... i dont understand that, because yesterday , before i plugged in the HDD , at least i got into the OSX Installer itself. Ive tryed to plug the new HDD off but its the same issue.
