by: tekmik
#24712
Hi, I cant even get this to finish the install. I can get to disk utility , format my SSD with GUID Partition on USB caddy and everything goes along telling me 15 minutes to install, so I wait and seems that its going to work but each time with about 1 cm left it just either tells me that -
error occurred running scripts from Base System Resources.pkg
or I just get
unable to install OSX on this disk and a error log
Anybody any ideas? I've searched about but everyone seems to have the issues post install and I can't even get to that bit yet
Any help or reassurance would be much appreciated, using the latest Sierra AMDV4 dmg from site and have now redone the usb pendrive twice with Transmac just incase it didn't take.
#24730
It may be a bad image restore. Try restoring the DMG again but use SierraAMD 4.5
by: Hurlburt
#25460
vitorlarge wrote: Mon Aug 07, 2017 11:58 am @tekmik, Check if the date and hour are correct. You can use testogen and have a bad HDD
Thanks for the helpful guide! Took me a while but I finally got it installed. :thumbup:
by: Norton287
#37402
mcpoesen wrote:If I click on Boot macOS from HighSierraAMD then my pc reboots and get the same option menu?
Follow the first part of the tutorial here for replacing a key file: viewtopic.php?f=24&t=3460
by: mcpoesen
#37403
Norton287 wrote: Wed Feb 07, 2018 3:08 pm
U mean ADD APFS SUPPORT TO HIGHSIERRAAMD V2?
And How to add the file into the system because I cant open the drive on windows? It must be formatted then
by: Norton287
#37404
Read further down about OSXAptioFixdrv, it shows you how to mount and you need to download that file and place it on the USB.
by: mcpoesen
#37405
Norton287 wrote: Wed Feb 07, 2018 3:17 pm Read further down about OSXAptioFixdrv, it shows you how to mount and you need to download that file and place it on the USB.
I dont get it? Can u sent a screen of the tutorial if I press CTRL + F en search "OSXAptioFixdrv" nothing found?
  • 1
  • 10
  • 11
  • 12
  • 13
  • 14
