by: vitorlage
#20401
Try again with this
I've been able to run El Capitan with 7790 but my processor was not an FX. With the FX's you have graphic acceleration but also green graphic glitches the icons disappear.
This is from a guy that has made it work, but he have an Intel processor
(4.39 MiB) Downloaded 31 times
(2.08 KiB) Downloaded 32 times
by: rohan
#20404
vitorlage wrote: Fri May 26, 2017 4:08 pm Try again with this
Tried everything bro no luck :(
by: bofe
#20449
Hi,
I'm trying to write sierraAMDv4.dmg to my 32GB sansdisk usb
The progress bar gets around 1/4 of the way along and then I get an error dialog box 'Could not write to Mac volume'. I have no idea if it has written properly. I'm trying to boot it from VMware workstation 12.5 unlocked, and just get 'EFI unsuccessful' errors. Any ideas?
Thanks
by: bofe
#20484
@vitorlagee Yep been following the tutorial but no luck on my main PC. Just tried with my laptop though and it worked first time. Must be something that I have installed that's interfering with the process. Now on to the next step. Thanks for your help!
edit: still having no luck booting. Maybe I should wait until Shanee gets his VM image updated with Ryzen support, I've wasted an unholy amount of time already :D
by: justinghawk
#20507
I ran Enoch and after trying to boot macOS, it just runs the normal boot then restarts the computer. Do I need to completely restart the process? :(
by: justinghawk
#20512
vitorlage wrote: Sun May 28, 2017 2:24 pm @justinghawk, Have you already created an account ?
Yes, Is there some sign in i'm suppose to do because it basically just does a bunch of black screen white text then restarts.
  • 1
  • 9
  • 10
  • 11
  • 12
  • 13
  • 14
