by: ToFailToWin
#19681
  • Alright, so how do you really Install Sierra?
    Well first off, ALL AMD FX Series CPU are Supported
    What you want to do , get Trans mac (14 day trial) then download SierraV3 from the download section from this site . Inside that file there is a doc, open it and go to either the cloud link or the google link, both would work. Once it starts downloading prepare your boot device.
    If you have a USB3 usb stick and a USB compatible computer, use that, You will need a 8 gb Flash Drive.
    Once you installed Transmac right click it and open it using Administrator, wait and click run.
    Once your in it find your usb drive and right click on it. Click format for mac format.
    confirm everything by clicking okay then once you have Sierrav3.dmg downloaded ,
    click restore mac image and find that file (Sierrav3.dmg) then click okay, wait till it finishes and reboot your computer.
    WHEN THE COMPUTER IS PUTTING PRESS EITHER F8, F12, OR F2 DEPENDING ON YOUR COMPUTER.
    Once your in bios. Locate your boot page, you'll see drive boot priority.
    Make your USB number one in the boot priority
    SAVE CHANGES :)
    Once you've done that restart your computer and let it boot.
    You'll come to a page that will give you options,
    BOOT TO THE ONE THAT SAYS SierraAMD
    Once youve let it load into it, you should get a prompt , click continue ONCE
    Once you see the Top bar load , go to Utilities and select Disk Utility.
    Once in there, find the hard drive you want to format
    (WARNING THIS WILL MAKE YOU LOSE ALL YOUR FILES, MAKE SURE THIS IS THE DRIVE YOU WANT TO FORMAT!!!!!! THIS FORUM NOR I AM LIABLE FOR LOST DATA!!!!)
    Click format and make sure its Macintosh Extended Journal also change the name of the drive to ( macOS )
    NO "()".
    Then click okay , let it finish and exit that window. Click continue until you get to a page that says
    "Choose drive that you want macOS to install to."
    Click the drive macOS and click continue, do not click anything else.
    Wait till it is done!
    The computer will reboot
    Again continue to boot to SierraAMD, click continue once, then click on Utilities.
    Open terminal, Once your in there, run these commands.
    cd /Volumes/SierraAMD/PostInstall
    cp -rf kernel /Volumes/macOS/System/Library/Kernels/
    cp -rf Extra /Volumes/macOS/
    cp -rf Kexts/*.kext /Volumes/macOS/System/Library/Extensions
    rm -rf /Volumes/macOS/System/Library/PrelinkedKernels/prelinkedkernel
    kextcache -u /Volumes/macOS
    reboot
    Once the computer reboots, its time to go into mac os, once your in the boot manager , use the arrow keys on your keyboard the select macOS
    Let it boot and wait
    Once your in there, click okay but when you get into the Apple ID section
    Click Dont have an Apple ID, click skip and skim through the install.
    Once you've done that, wait and youll be prompted with keyboard detection failure, follow through it
    (DONT WORRY IF THAT DOESN'T POP UP)
    Once your in there, copy the Post install to your desktop
    Open Enoch first
    run that by going to the settings,
    Privacy and Security
    And press Open Anyways and Press run
    Once you get to the Installation Guide, press continue
    Once your done with that, Reboot your computer
    Enter the bios
    Go to your Boot Priority Page
    Make your Drive that you've install Mac on the First Boot
    then Unplug the USB Stick
    Save Changes and reboot.
    Once that's done youll boot and then just run macOS
    and you're done.
If you have any issues, comment and I'll gladly try to help and so will the Developer :)
vitorlage, jaydino, synthy liked this
#19737
eritxo wrote:After 10 or 5 min the screen freeze or the PC shutdowns
You'll need to enable the GPU. Install Clover and set an ATI FakeID of 0x68101002 and it should work.
by: Deleted User 2345
#19746
I don't know why but I can't boot Clover...
I can't mount EFI
#19749
Boot with Enoch and configure the config.plist then try booting with Clover.
#19754
Shaneee wrote:0x68101002
Spoiler:
Like this?
Which boot flags I should use?
#19757
Yeah then in the Graphics tab set the Framebuffer (FB) to Radeon and try booting.
#19766
Shaneee wrote:Yeah then in the Graphics tab set the Framebuffer (FB) to Radeon and try booting.
Clover error booting
This version of Mac OS X is not supported on this platform!
REason: Mac-F42C88C8
by: ToFailToWin
#19769
@eritxo, boot with -no_compat_test
#19771
ToFailToWin wrote: Sat May 20, 2017 8:51 pm @eritxo, boot with -no_compat_test
-no_compat_check*
But now I can't boot it stuck on
  • 1
  • 2
  • 3
  • 4
  • 5
  • 14
