by: Valamyr
#45386
Hello, That does not seem to work in Mojave. Despite I change "Unknown" to some other value I still have Unknown in about my Mac.
Cheers!
by: Valamyr
#45441
@Marcyvee, yep but unfortunately it does not work.
Cheers!
by: flek999
#45646
@Valamyr @Marcyvee
It's working on Mojave when "Unknown" is shown. The path is different: System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/Resources/
And then it depends which language do you have set up in OS X. For me English.lproj wasn't working. I have GB language turned on so I need to go to 'en_GB.lproj' directory, and then change Unknown. It's working like a charm.
by: Darran T
#45660
frle10 wrote: Fri Sep 01, 2017 8:42 am Hmm, I also have unknown and I tried the thing with TextWrangler but when I try to save I get an error saying:
The authenticated save for this file failed (application error code: 20004)
Copy it to your desktop first. Edit and save that copy, then move it back to the correct folder. That worked for me.
Thanks Shaneee for this. I changed mine to reflect the correct CPU. On a more just-for-fun topic, how did you change the computer type to AMD MacPro. Mine currently lists iMac (27-inch, Late 2013).
Thanks
Darran
by: Jono4191
#46017
@Shaneee Could you please provide me the file for my CPU?
AMD Ryzen 5 1600
High Sierra 10.13.6
Thanks mate!
by: KojiAiba
#50780
Shaneee wrote: Thu Jun 01, 2017 12:54 pm If it's showing as Unknown then navigate to System\Library\PrivateFrameworks\AppleSystemInfo.framework\Versions\A\Resources\English.lproj and open up AppleSystemInfo.strings in TextWrangler. This app is on the App Store. Find the following and change it to what you want,
	<key>UnknownCPUKind</key>
	<string>Unknown</string>
	<string>FX-8370</string>
Fantastic!
Except textwrangler wont launch on my OS and i tried other editors plist is in binary, so you can't edit it in binary without proper editor...
No other solution than textwrangler ?
