#16929
The image was corrupt so I removed it from the server. I'll ask IncognitoJam if he plans to remake/reupload it. You can also use my Sierra image.
by: Chad
#17024
tianjianyu wrote:Don't need to replace the kernel?
This seems a little out of context, though I think the answer you're looking for is no. This image has the kernel pre-installed. You'll only need to replace the kernel after the macOS installation.
Shaneee liked this
#17912
Hi , I need help,
PS : sorry if my english is very bad because i'm french =)
I download the image , restore the USB key with the image in Disk Utility.
I prepar my bios and i boot one the key but i have a message that the system-file are not readable...
Could you help me ? , I probably missed a step
Thank
#17959
Which image did you download exactly?
