by: alexuss88
#25245
Shaneee wrote: Tue May 23, 2017 7:23 pm
ssen8 wrote:@Shaneee
Thanks for the hard work.
Just a recommendation
The steps you gave for post install script post.sh, that needs a little correction
What you gave as steps :
cd /Volumes/SierraAMD/PostInstall
sh post.sh
What it should be :
sh PostInstall/post.sh
Because when you read the scripts it asks to copy from PostInstall/kernel
however when I run the script after going in the PostInstall directory, the script is not able to find the path PostIntall/kernel as PostInstall is the parent directory of post.sh
due to which the post installations fail for all the commands in the script.
I've adjusted the instructions here, http://forum.amd-osx.com/app.php/sierraamd-post-install
Thank you! Failed to execute the command earlier! I thought I did something wrong, or the equipment does not fit. :thumbup:
by: 丿绪丨灬
#25734
Shaneee wrote: Wed Jul 26, 2017 12:43 pm @丿绪丨灬, Best to install on GUID. To install on MBR you need to make modifications to the installer.
@teamgbz, Does TransMac close or just stay not responding? Just leave it and it should work.
The meaning of the tutorial is that I need to use USB again into the installation interface.right?
I'm really sorry to ask you this question after so long.
#25957
@丿绪丨灬, Yeah you need to boot the Install once more to run post install and boot the HDD. Once done you can install the boot loader to the HDD.
by: swipii
#27422
Doesnt work for me. Kernel Fail when try to Install or Boot Or whatever from USB Stick AMD5 ..
by: Norton287
#27424
You may have a corrupt download, I'd download again and remake the USB Installer.
swipii liked this
by: swipii
#27432
Thank you - that was exactly the fault. But its not working anyway. (Made a Post about it) But thanks!!
by: lemonasterien
#27800
Hi all
After installing from usb, I tried booting from HDD, but I get a red screen, stucked ...
Any ideas ?
Thanks
