#11427
Ok then nv_disable=1 let you in. Replace the kernel and remove the flags from /Extra/org.chameleon.Boot.plist and reboot still with nv_disable=1 as you'll need to disable the card for now. What is the GPU exactly?
by: brickman7713
#11437
Ok, I'll try that later tonight when I get home again. The only thing I know about the gpu is in my signature. thanks
by: brickman7713
#11455
Shaneee wrote:Ok then nv_disable=1 let you in. Replace the kernel and remove the flags from /Extra/org.chameleon.Boot.plist and reboot still with nv_disable=1 as you'll need to disable the card for now. What is the GPU exactly?
Ok, now I can't get by this after login. What am I doing wrong?
Sent from my SM-G920V using Tapatalk
#11475
Either press cancel or press the Esc key on the keyboard. It shows when the system wasn't shutdown correctly.
by: brickman7713
#11491
Shaneee wrote:Either press cancel or press the Esc key on the keyboard. It shows when the system wasn't shutdown correctly.
Ok, I got by that with "npci=3x3000 nv_disable=1" can I rename the kernel to something like amd16 and the boot "amd16 npci=3x3000 nv_disable=1"?
#11493
You don't need to rename it at all. If it's in the correct folder System/Library/Kernels and you've not got the old kernel bootflag there it will use it by default. Upload your org.chameleon.Boot.plist file if you aren't sure.
by: brickman7713
#11499
Ok, how do I know if it's booting with that kernel?
#11505
If it's in the kernel folder it's used by default as that's where it should be.
by: brickman7713
#11520
Ok, it's in there so it must be using it.
#11525
Can you upload your org.chameleon.Boot.plist file so I can check it's not calling the old kernel.
