by: brickman7713
#11346
Hello so I successfully installed Yosemite Niresh on my desktop but the graphics are really studering and the background is all colorful. Any suggestions? Thanks
by: Ackados
#11348
What are your graphics? If NVIDIA, try this bootflag: nv_disable=1
by: brickman7713
#11357
Ackados wrote:What are your graphics? If NVIDIA, try this bootflag: nv_disable=1
Sweet that helped me get by the lock screen but the background is still the same. Any other suggestions? Thanks
Sent from my SM-G920V using Tapatalk
#11364
Ohh wow. I suppose you are using the kernel that came in the image? Try updating it to the one on our downloads page. Replace the one in System/Library/Kernels and remove the /amd bootflag.
by: brickman7713
#11402
Ok, thanks. So I download the Yosemite kernel from the download page and just copy to System/Library/Kernals? Thanks again shane
#11404
System/Library/Kernels Yes also then boot with -v UseKernelCache and make sure to remove the /amd or /amd64 bootflag or it won't use the new kernel.
by: brickman7713
#11405
Okay thank! I will try it when I get back home.
by: brickman7713
#11416
Hey is there anyway to change the kernel without having to login? I'm stuck on the spinning wheel again when I enter my password.
#11419
Boot with -x to access the system.
by: brickman7713
#11425
Thanks, I got by the login without using -v and using nv_disable=1. But I can't boot -x UseKernelCache nv_disable=1
