by: EpicTgames
#11059
im running yosemite 10.10.5 using this sites kernel, everything is working but after installing nvidia web drivers that correspond to my build,
i notice alot of loading and sudden freezes .
Really need help here ASAP :(
(Big thanks to shaneee for making this Amd Support :thumbup:
#11062
What's your Specs and after installing the web drivers are you using the bootflag nvda_drv=1 ?
by: EpicTgames
#11073
Yes Im using nvda_drv=1 and -f -v npci=0x3000.
GTX 950
AMD ATHLON X64 860k 3.7 ghz
8gb ram
Hard Drive 80 GB
Its not hardware issue since windows is perfect but i get freezes in mac os x yosemite 10.10.5 (14F27)
#11113
Try this kext replace,
http://www.insanelymac.com/forum/files/file/354-amd-replace-kext-for-yosemite/
