by: ddonnie
#10444
I'm looking for the correct kexts to get everything working properly. My onboard sound is Realtek ALC887 and my ethernet is realtek 8111E. My video card is a GTX550Ti. Thanks for the help!
#10454
For Audio use this,
http://amd-osx.com/files/VoodooHDA.kext.zip
For the LAN use this,
https://www.dropbox.com/s/tn8nwnrv1y7f5zp/RealtekRTL8111.kext.zip?dl=0
And for the GPU. Use this App to get the nVidia Web Drivers. After install you'll need to boot with nvda_drv=1
www.insanelymac.com/forum/files/file/474-nvidia®-webdriver-updaterapp/
by: ddonnie
#10504
Thanks for the reply. I'm not getting my email alerts for some reason so I'm just now seeing this. I ended up using a distro (I'm sorry! ) and most everything is working, but I'm getting a random kernel panic. Any ideas?
#10526
Did you select a USB fix in the installer at all? It's panicking on the USB kexts.
by: ddonnie
#10528
Shaneee wrote:Did you select a USB fix in the installer at all? It's panicking on the USB kexts.
i dont believe i did. I didnt realize it was an issue with yosemite.
#10529
USB 3.0 has some issues on Yosemite. You can try updating the kernel to our one from the downloads as I assume you're using the one that came in the Distro?
by: ddonnie
#10693
I'm actually using a different one that fixed a video issue i was having. Do i need to install any additional kext's when using the one hosted here or just swap the kernel?
#10706
No it's just a kernel swap.
