by: Matthew
#8115
Shaneee wrote:Have you tried adding your device ID as in the first topic I linked to?
Yeah, just not sure if i've tried it correctly :lol:
 <key>IOPCIPrimaryMatch</key>
			<string>0x10029902</string>
#8121
Did you repair the kext permissions and boot without caches after modifying it?
by: Matthew
#8125
Shaneee wrote:Did you repair the kext permissions and boot without caches after modifying it?
well I just dropped the file into kext utility and rebooted. how does a man boot without caches? :D
#8126
Boot using UseKernelCache=No
by: Matthew
#8131
Shaneee wrote:Boot using UseKernelCache=No
No outout devices found for voodoo hda
I feel like either kext utility isn't working correctly or I put the device ID in wrong.
#8132
You can find the device ID in Windows :thumbup: Try asking on the InsanelyMac site in the VoodooHDA section. I'm not that sure on how it works exactly.
by: Matthew
#8136
Shaneee wrote:You can find the device ID in Windows :thumbup: Try asking on the InsanelyMac site in the VoodooHDA section. I'm not that sure on how it works exactly.
i used the one it showed me in dpci manager on OS X for my headset :shifty:
on Windows would it be in device manager?
#8138
Yeah the device for the sound chip will most likely be different than your headset.
by: Matthew
#8217
Shaneee wrote:Yeah the device for the sound chip will most likely be different than your headset.
not working :evil:
no outputs found voodoohda. again.
#8235
You're running 10.10.1? Try updating to 10.10.5. You can follow my El Capitan tutorial but obviously replace the kernel with the Yosemite one and use the correct update. It may work better on a more recent system.
