by: Matthew
#8068
Still haven't found a fix for this and it really irritates me. The sound crackles and delays so bad that I may as well say I have no sound. To date, I've tried:
Reinstalling (multiple) voodoohda kexts
Completely uninstalling voodoohda
Using multibeast to install Realtek ALC driver
Booting with and without headset plugged in
All without any luck
Does anyone else have any ideas? It's not a headset thing, at least I think so because playback from all other outputs I could try was not better nor worse for that matter whatsoever :thumbup:
#8072
VoodooHDA is the AMD choice unless you've got a NForce chipset which will allow a patched AppleHDA. Have you checked this page,
www.insanelymac.com/forum/topic/267905-voodoohda-common-problems/
by: Matthew
#8083
Shaneee wrote:VoodooHDA is the AMD choice unless you've got a NForce chipset which will allow a patched AppleHDA. Have you checked this page,
spent the past hour trying various fixes. i think im going insane. i feel like theres less crackling now but its still not usable :lol:
#8085
Have you used the latest version? v2.8.9 I think it is.
by: Matthew
#8088
Shaneee wrote:Have you used the latest version? v2.8.9 I think it is.
2.8.4.. could it really be that simple? Going to try installing 2.8.9 now then
#8090
There are also changes you can make to the kext to try fix it. I think Slice has it documented somewhere.
by: Matthew
#8092
No luck. The problem persists even with latest voodoohda version :wtf:
Messed with the info plist a bit as shown in that post on insanelymac and now it says there are no voodoohda outputs found
I'd love to see slices docs on this then
#8093
Have you tried adding your device ID as in the first topic I linked to?
by: Valkiry
#8094
My board has ALC892 and VooDooHDA works just fine. I'll send you my kext
by: Matthew
#8114
Valkiry wrote:My board has ALC892 and VooDooHDA works just fine. I'll send you my kext
Please do, would appreciate it :)
