by: OSXF
#5473
Just wondering as I am using 10.10.1, is there any sense to update to the latest version. I am talking about the features and performance as well as security updates but I was using AMD processor, so I am curious about the other stuff like kernel etc. :crazy:
#5483
Yeah you can update but not with the App Store. You can follow my 10.11.6 update tutorial found here, viewtopic.php?f=24&t=428
But use the kernel for Yosemite from the downloads page and this combo update rather than the one in that topic,
https://support.apple.com/kb/dl1832?locale=en_US
by: Serenity
#23654
there is no system.kext and when I run the repair command I just get / locked; waiting for lock. I'm super scared to reset my computer lol
#23680
The System kext isn't required. Wait until that command has finished. It'll jump to a new command line like when you started once done.
