#31721
My Radeon HD 5750 kexts I got for 10.10.0-1 don't seem to quite work with 10.10.5. The drivers themselves work just fine, but the frame buffer doesn't work properly and cause problems with lagginess and screen refresh. I'm wondering if anyone has a more up-to-date file or if I am doing something wrong. I've tried messing with some settings in Clover to fix it but to no avail. I appreciate any help.
Specs:
GPU: ASUS ATI RADEON HD 5750 1GB (0x68BE1002)
CPU: AMD PHENOM II X6 1035T @ 2.6GHz
RAM: 8GB DDR3 @ 1333MHz
MOBO: ASUS CG1330 (M4A78LT-M)
BL: Clover latest version
EDIT: Not sure if relevant, but on one boot, I saw that the AMDX3000Controller.kext failed to load. It only seemed to happen that one time so I'm not certain that's the culprit.
#31742
There are many major changes in the drivers since 10.10.3. You can't just port the 10.10 kexts to 10.10.5. viewtopic.php?f=24&t=2976
Sophie-bear liked this
#31757
AlGrey wrote: Thu Nov 09, 2017 2:24 pm There are many major changes in the drivers since 10.10.3. You can't just port the 10.10 kexts to 10.10.5. viewtopic.php?f=24&t=2976
Fantastic, wish I could have found this thread when I was searching. I'll give it a shot and report back with results. Thank you!
Edit: I still need proper versions of the Framebuffer kext, etc., right? Because I can't seem to find those anywhere for 10.10.5...
Edit 2: After installing the AMD/ATI kexts ripped from the 10.10.5 Combo Update, this solution works flawlessly!
#31822
:thumbup:
