by: SleepingPanda
#20772
Shaneee wrote: Wed May 31, 2017 7:41 pm Open Terminal and run the following command and see if it completes.
sudo kextcache -u /
Yup, here's the result (along with a kernel panic I get every 5 mins):
Running Enoch after doing this still fails BTW.
by: Sundhar88
#20782
@SleepingPanda, Show log files during installation. Its in the menu bar under window option, i think
I had the same problem because the installer cant create prelinkedkernel.
#20795
No problem with the kernel cache then. As Sundhar88 has mentioned. When Enoch fails open the installer log from the Window menu bar option and set it to show all errors.
by: SleepingPanda
#20800
Sundhar88 wrote:@SleepingPanda, Show log files during installation. Its in the menu bar under window option, i think
Shaneee wrote:No problem with the kernel cache then. As Sundhar88 has mentioned. When Enoch fails open the installer log from the Window menu bar option and set it to show all errors.
Here's what the log outputs:
The actual log window doesn't do line wrap and error line scrolls off screen so i saved it as a text file and took this photo of the line with the error since i knew i wouldn't have enough time to transfer it before the kernel panic.
#20802
Did you change the log to show all errors? Do that and just take a pic of the log it's self. You won't need to save it. Also what does the KP relate to?
by: SleepingPanda
#20804
Shaneee wrote:Did you change the log to show all errors? Do that and just take a pic of the log it's self. You won't need to save it. Also what does the KP relate to?
Alright I retook photos. Here's the log:
And here's the KP:
#20807
You need to change the log to show all messages. It's the dropdown on the left. As for the KP you are missing NullCPUPowerManagment.kext.
by: SleepingPanda
#20813
Shaneee wrote:You need to change the log to show all messages. It's the dropdown on the left. As for the KP you are missing NullCPUPowerManagment.kext.
Finally understood what you meant, sorry.
Here are the pics:
Thanks for the tip on NullCPUPowerManagement.kext! I installed it and the other kexts so hopefully that problem is solved. (haven't seen a KP yet)
by: DCShoes
#20845
Try another version of chameleon and see if install complete... After installed you can copy/paste a working build. I used this trick in my older machine, with a problem in the same crap. 8-) 8-)
by: SleepingPanda
#20895
DCShoes wrote:Try another version of chameleon and see if install complete... After installed you can copy/paste a working build. I used this trick in my older machine, with a problem in the same crap. 8-) 8-)
You mean Enoch? I tried using the latest version already and got the same error. No dice :(
