by: Mattvenner
#18105
Hi sorry if this has been already answered. Does the serial number affect the App Store? I've seen some setups with no serial and the App Store works fine. If it does how do you generate one for an amd? Thank you very much.
#18134
I don't think it's needed for the App Store. Do you not have one set? It's done in the SMBios.plist file.
#18269
Are you using Enoch? There should be an SMBios.plist file in the Extra folder.
