Development and testing of modified XNU Kernels for AMD CPUs on OS X
by: jacfen123
#8425
I am also getting the Invalid kernel opcode error and halts as verbose is started.
#8426
As a note this is where my system hangs,
by: jacfen123
#8427
Oh, mine isn't hanging like that. I press enter to boot and then the screen is filled with text saying "invalid kernel opcode".
#8428
Yeah I get that if I boot without the kernel cache. This is on an installed system with the prelinkedkenrel built.
by: jacfen123
#8430
Yeah, I wasn't able to install yet.
Does anybody have any suggestions of kernel flags that I could try?
#8432
I installed if from El Capitan to make testing a bit easier :thumbup: :lol:
No boot flags will sort it. It's an error in the kernel.
by: jacfen123
#8433
Oh alright. I would try to upgrade my Yosemite installation but I don't want to break my system. :lol:
#8434
It's installed on a separate drive. I just ran the OSInstall.mpkg from the packages folder and added in the missing files :) Once the kernel works you'll be able to install correctly :thumbup:
Try this one if you want.
(3.98 MiB) Downloaded 30 times
by: jacfen123
#8435
Alright, I'll give this one a shot.
[EDIT]: I used the new kernel this time and instead of it only saying invalid kernel opcode, it was also saying something like this: (It was scrolling really fast, but this is what I was able to gather from it) ".....System won't be able to boot....".
by: darklord42
#8439
Sounds like progress to me! :thumbup:
