Development and testing of modified XNU Kernels for AMD CPUs on OS X
by: saturn
#7030
tuning into this thread - I'm on an FX chip and also see the goofy glitches. awaiting a solution. let me know if there's anything I can do to help.
by: Valkiry
#7031
FX Users will face small graphical glitches. A fix is being investigated. More info here, or visit here to help with testing
viewtopic.php?f=14&t=103
viewtopic.php?f=14&t=496
Also check out insanely macs amd kernel task force
#10595
I've built a new kernel for FX El Cap if someone wants to test it out and report back.
(4.22 MiB) Downloaded 26 times
by: darklord42
#10621
Hi, I gave it a shot for jokes. Anything to fix this icon issue. :)
Unfortunately it failed to boot with this error:
panic  (cpu 0 caller 0x<ptr>: "Unable to find driver for this platform :  \"ACPI\" \[email protected]/users/shaneee/Desktop/xnu-3248.60.10/iokit/kernel/IOplatformExpert.cpp:1623
Hopefully that is useful too you.
#10634
darklord42 wrote:Hi, I gave it a shot for jokes. Anything to fix this icon issue. :)
Did you create a prelinkedkernel against it?
by: darklord42
#10655
Nope, sorry, where do I find info on that process?
#10657
darklord42 wrote:Nope, sorry, where do I find info on that process?
Are you testing on another partition?
sudo kextcache -u /Volumes/"Partition Name"
by: darklord42
#10659
Oh crap, I'm remembering the process now. I'll have to try it tomorrow.
#10662
darklord42 wrote:Oh crap, I'm remembering the process now. I'll have to try it tomorrow.
Just when you get the time. Thanks for testing.
by: darklord42
#10819
Sorry for the delay. I finally found time to give it another go. This time remembering to create the prelinkedkernal. Unfortunately, It had the same result as before which is disappointing. I was hoping for a new error. ;)
