Development and testing of modified XNU Kernels for AMD CPUs on OS X
#5195
I'd like to ask any FX users or others facing the same glitches to help with testing.
Before you proceed I highly recommend either installing onto another partition on your OS X drive or cloning your current one with an app like Carbon Copy Cloner.
To test the kernels copy the test kernel into /System/Library/Kernels/ of the test drive then delete the folder named com.apple.kext.caches located in /System/Library/Caches/. Then delete the file prelinkedkernel located in /System/Library/PrelinkedKernels/.
Then run the following in terminal replacing Test Drive with the name of your test drive,
sudo kextcache -u /Volumes/"Test Drive"
Reboot into the test partition/drive with -v to monitor the boot. Once booted if it does boot as not all test kernels will. Run the following command in terminal,
sysctl -a
Then copy the output of the Terminal window into a reply here using the
 BBCode, the icon in the reply window looks like this,  [size=150][b][fa]fa-code[/fa][/b][/size]
If you're testing another file I've uploaded simply replace the original with the one I've uploaded and report.
Once again please don't test on your main install of OS X for safety.
by: NicoM4491
#5406
Shaneee wrote:I'd like to ask any FX users or others facing the same glitches to help with testing.
sysctl -a
To start with here is a kernel to test,
kernel.zip[/quote]
I´m in man! give me till tomorrow and i´ll post the results... this kernel works on the graphical glitch?
#5422
@NicoM4491, This is to try and fix the graphical glitch. I can't guarantee it will work straight away but with testing we can see what is still needing work.
by: ksxi
#6035
@Shaneee I will try this tomorrow! Sorry haven't been active here for a while
#6042
ksxi wrote:@Shaneee I will try this tomorrow! Sorry haven't been active here for a while
I should have removed the kernel sorry. It didn't fix anything. There will be a new one to test soon.
by: ksxi
#6048
Ahh no problem, I also realised that I was running Yosemite, need to install El Cap again lol
by: denali
#6295
I'm willing to help test. My Mac setup is basically so I can learn and eff around with anyway, so if something goes off the rails, I'm not going to whinge about it.
by: lordsith82
#6513
MadmanGFX wrote:Have we had any success building a working fx kernel?
My system is stable... only problem is the hated icons! :)
by: MadmanGFX
#6514
I managed to get mine stable as well, like you said the icons are annoying. I was hoping someone had a solution for that
